Powering the EL wire pocket inverter
Postby MaxQ » Mon Aug 08, 2011 4:25 am
I am planning a project that uses the Arduino and EL wire.
I was wondering if I could use one of the Arduino's 5V digital pins to power the pocket inverter, instead of 2 AA batteries.
Ideally I'd run a wire from the pin to the hot contact of the inverter, and a wire from the other contact to Arduino's gnd.
This way I will be able to directly control flashing speed and sequences with the Arduino.
MaxQ
Re: Powering the EL wire pocket inverter
Postby adafruit_support_bill » Mon Aug 08, 2011 5:17 am
The Arduino pins won't supply enough current to drive the inverter directly. But they could drive a transistor to switch current to the inverter.
Postby MaxQ » Mon Aug 08, 2011 5:46 am
So I would still need the AA batteries?
MaxQ
Postby adafruit_support_bill » Mon Aug 08, 2011 6:06 am
AA's or some other 3v supply. (don't try to use the 3.3v pin on the Arduino. That is only good for a few milliamps!)
Postby MaxQ » Mon Aug 08, 2011 6:39 am
Yes, I realized that that was the problem.
How much current does the inverter require?
So I know which transistor to get...
MaxQ
Postby adafruit_support_bill » Mon Aug 08, 2011 6:54 am
It depends on the load. With a couple meters of EL wire, it will draw about 250mA.
The inverter in the store is not really a good candidate for switching. It has a single push-button control that cycles through the three modes: steady/blink/off.
Postby adafruit » Mon Aug 08, 2011 4:18 pm
we'll have a 12V inverter for the EL wire in the shop shortly, which at least is easier to wire to
Postby MaxQ » Tue Aug 09, 2011 6:51 am
What's the logic behind the push button? Will I be able to directly access that and send it bits?
MaxQ
Postby adafruit » Tue Aug 09, 2011 1:31 pm
there is a driver chip in the inverter that uses the button. not sure what the 'interface' is
you should use a triac like every other EL control project uses. don't mess with the inverter
Postby MaxQ » Wed Aug 10, 2011 3:17 am
Alright, thanks.
MaxQ
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
