Ice Tube Clock Kit Problem
Tick Tock Clock Kits
Postby rangerofthewest » Sun Aug 07, 2011 2:24 pm
My ice tube clock kit when I measure the boost (the one that you are supposed to read 40-70 volts on your multimeter) read 9 bolts. Furthermore, I did not recieve a beep from the piezo. Is this normal? And any troubleshooting on the boost converter? :?: :?: :?:
rangerofthewest
Re: Ice Tube Clock Kit Problem
Postby adafruit_support_bill » Sun Aug 07, 2011 7:14 pm
If you didn't get a beep, then the processor is not running and not generating the boost signal. Post photos of the front & back of the board and we will check for any assembly problems.
Postby adafruit_support_bill » Mon Aug 08, 2011 8:19 pm
Well, the pics aren't coming through. But something must be preventing the processor from running. Re-check the 5v supply, and also double- check the color codes on R1, R2 & R5.
Postby rangerofthewest » Mon Aug 08, 2011 8:27 pm
Here are the pics. It might be of value to tell you that the beep occured on the test after placing the microcontroller, but this time it didn't.
Back of board
Small 6.png (585.98 KiB) Viewed 1194 times
rangerofthewest
Postby rangerofthewest » Mon Aug 08, 2011 8:28 pm
Front of board
small 7.png (576.54 KiB) Viewed 1194 times
rangerofthewest
Postby rangerofthewest » Mon Aug 08, 2011 8:29 pm
More pics
small 8.png (578.08 KiB) Viewed 1194 times
rangerofthewest
Postby rangerofthewest » Mon Aug 08, 2011 8:30 pm
one more angle... HELP!!!
small 9.png (575.05 KiB) Viewed 1194 times
rangerofthewest
Postby adafruit_support_bill » Tue Aug 09, 2011 4:38 am
The photos are a little dark, but the color bands on R2 don't look right. Did you perhaps get R2 and R5 mixed up? Check the color bands on the parts list: http://www.ladyada.net/make/icetube/parts.html
Return to Clocks
New Products [103]
LEDs[109]
Cables[61]
