WB RC1 Fixes
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
WB RC1 Fixes
Postby hahahehihoha » Mon Feb 12, 2007 12:09 pm
I'm looking for feedback to the following fixes I have formulated. Are these correct?
A) TX/RX paths swapped: going from 4pin jumper to microcontroller. This is because of the TX/RX from the FT232 into the jumper makes it necessary.
B) Ring/Tip switch on the DC jack: The two pads in the image below need to be swapped with their connections maintained.
C) The 0.1uF caps on top of the 10K 1206 resistors in the PLL section can be placed in parallel somewhere BESIDE the 10K resistors on the board.
D) The MIC2506 voltage boost regulator rated for 7.5V max is receiving 13.5 V, as reported by another WB assembler. This can only be from pins 1 or 4 which are connected to the other voltage regulators and the microcontroller at pins 1 and 8 respectively. How do I fix this with the a resistor?
Ciao !
hahahehihoha
Postby budzeg » Mon Feb 12, 2007 3:40 pm
i'm yet to build the ckt but as soon as i do, i'll give u a feedbk
budzeg
boost voltage regulator
Postby jc » Mon Feb 12, 2007 6:55 pm
I have built 2 working wave bubles and here is how I overcame the issues you are having.
A) yea they are just swapped. All you need to do is cut the traces on the board and use some jumper wire to reconnect them. The simplest fix unless you want to edit the board before you ship it off for etching.
B) this is a little harder. I will refer you to my post on my site where I have a picture of how I cut what traces and where I reconnected them.
C) just stack the buggers. Solder the caps on then tack the resistors right on top of them. Any other fixes are just thinking too much and too much work. Remember KISS.
D) DO NOT USE THE R3 value or you will fry IC 10 (MIC2506 power switch) to overcome this voltage just swap out the resistor with a smaller value. Look to the datasheet for the equation to calculate it. I just changed R3 to 36.6 ohms at 1% and got 4.95-4.98 volts. Close enough.
http://corl.homedns.org/electronics/?p=21
John
jc
DC jack fix
Postby none_such » Mon Feb 12, 2007 10:36 pm
You need to cut all the traces (three landings - two input values since to of the terminals are connected). Could you just reverse the polarity on the input charger?
Cheers
none_such
DC jack fix
Postby none_such » Mon Feb 12, 2007 10:57 pm
That is, reverse polarity and cut and jumper one trace
none_such
Postby jc » Wed Feb 14, 2007 7:16 am
no you cant just swap the voltage on the external PS. the pin gets shorted to allow the internal voltage to get passed thru.
John
jc
fixed completion
Postby hahahehihoha » Wed Feb 14, 2007 2:39 pm
Hat off to JC for the pointers, finalized PCB and sent off to APCircuits.
keeping it complicated:
C) resistors on caps preferable to viceversa?
D) R3 is reference to the mainboard component list ? (120 K ohm to 36.6 ohm seems a big leap and while I can obtain and read datasheets at a novice level, this I could not grasp).
Thanks,
outta here, and will report back with assembly.
hahahehihoha
Re: boost voltage regulator
Postby yopper » Fri Feb 16, 2007 4:48 pm
jc wrote:D) DO NOT USE THE R3 value or you will fry IC 10 (MIC2506 power switch) to overcome this voltage just swap out the resistor with a smaller value. Look to the datasheet for the equation to calculate it. I just changed R3 to 36.6 ohms at 1% and got 4.95-4.98 volts. Close enough.
I assume you mean 36Kohm
(5.0 - 1.23) / 1.23 * 12K = 36.78K
What I don't understand is why the LM2733 is used as its web page states Output Min = 20 Volt Output Max = 40 Volt.
yopper
Postby adafruit » Fri Feb 16, 2007 6:08 pm
i think thats a typo: the example they give is for 12V!
http://www.national.com/pf/LM/LM2733.html
Postby yopper » Sat Feb 17, 2007 2:55 am
Hmm strange, still it seems the LM2731 is more appropriate. meant for a lower voltage range.
http://www.national.com/pf/LM/LM2731.html
yopper
oops
Postby jc » Sat Feb 17, 2007 6:29 pm
yea i typed that while i was a little tired. 36.6K Ohm Digikey part
311-36.5KFRCT-ND
Also in response to caps on resistors or resistors on caps. I found it easier to put resistors on caps because to the shape of the caps. your choice
John
jc
Return to Wave Bubble
New Products [103]
LEDs[109]
Cables[61]
