Monochron display problem- blank screen
Tick Tock Clock Kits
Postby Ryba11 » Fri Aug 19, 2011 4:01 pm
I recently soldered a monochron clock kit. when i plugged it in the first time as instructed it beeped as it was supposed to. when i finished the project everything was working and functioning besides the display. I adjusted the brightness to reveal what should have been the clock, but the lights on the screen all turned on all blank. Im not quite sure what the problem is, but the only thing wrong is that the screen displays nothing, even though it still works
here are some pictures
this is the screen turned on and plugged in. no display
Ryba11
Re: Monochron display problem- blank screen
Postby Ryba11 » Fri Aug 19, 2011 5:03 pm
if by contrast you mean the yellow screwdriver operated device then i did and it still i s blank.
Ryba11
Postby Ryba11 » Fri Aug 19, 2011 6:22 pm
nope. from beginning and plugging it in, there was never any animation on the screen. the electronics all work as the light lights up, the speaker beeps and the screen is lit, just no animation on the screen
Ryba11
Postby adafruit » Sun Aug 21, 2011 3:44 pm
hmm, do you mind resoldering all the LCD pins/connector and microcontroller? its something in between that is amiss :/
Postby Ryba11 » Mon Aug 22, 2011 11:25 am
I will do that and get back to you. perhaps it was a cold solder or something just went wrong
Ryba11
Postby Ryba11 » Tue Aug 23, 2011 3:10 pm
I have done that. I reheated each of the connection pins of the display: on the both of the boards and it still is displaying the same blank screen while I adjust the brightness.
Ryba11
Postby adafruit » Tue Aug 23, 2011 3:23 pm
OK we should try to send you a new display in case thats it - email support@adafruit and ask for a new Monochron display. If you don't have any extra header left over for another display, ask also for a 36 pin 0.1" header
Return to Clocks
Users browsing this forum: ArekKindAcere and 0 guests
New Products [113]
Raspberry Pi[81]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
