Remote Volatge Monitoring
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby WD8MBE » Tue Sep 06, 2011 7:08 am
Hi, name is Tom and I am new to the forum.
I have a solar and wind setup with everything located in my garage, including the storage batteries. I want to use 2 Xbees to monitor the voltages and send it to my PC located in the house.
Also, I would like to track these voltages over a given period of time. Can anyone help me on how to configure and wire the Xbees to monitor 10-15 VDC and 0-35 amps?
Thanks in advance,
Tom
WD8MBE
Re: Remote Volatge Monitoring
Postby franklin97355 » Tue Sep 06, 2011 4:20 pm
Have you looked at the Tweet-A-Watt project? It should give you some ideas for starters.
franklin97355
Postby WD8MBE » Fri Sep 16, 2011 2:06 pm
Hi Franklin,
Thanks for your response. I now have XBee's setup using the Kill-A-Watt software. And I am displaying using EnergyLogger.
Now the voltage sensor input (AD0/D100) what type and value of voltage is it expecting? DC Voltage, Micro Volts, AC?
Just for experimentation, could I hook a 1.5v AA battery to Grd and AD0 and get a reading. By the way, I am using Parallax 5v/3.3v adapter board.
Thanks,
Tom
WD8MBE
Postby adafruit » Thu Sep 29, 2011 1:58 pm
tweetawatt must be calibrated. thats why there is a calibration step. follow the tutorial for calibration and voltage checking
Return to XBee products from Adafruit
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
