Accent Out - Details?
Postby Syd » Sat Sep 03, 2011 9:47 pm
I am looking for more detail information on adding the Accent Out mod to a x0xb0x i'm building. I believe it is the same thing as the x0xi0 and the Devilfish mod version. I have not been able to find much info other then the signal is taken from pin 2 of vr4. More details or a schematic would be greatly appreciated.
Syd
Re: Accent Out - Details?
Postby guest » Sat Sep 03, 2011 10:19 pm
are you looking for a trigger out
from the accent
or an analog cv that represents the accent sweep
guest
Postby Syd » Sun Sep 04, 2011 1:14 am
As I understand it the Accent notes are sent out a separate output. Audio output.
Syd
Postby guest » Sun Sep 04, 2011 5:21 am
im not certain how its supposed to work
but if it is a seperate output
for just the accented notes
then it will require some more circuitry
and isnt just a wire tap
you would need another 4066
which would switch the audio signal
based on the accent trigger signal
guest
Postby Syd » Sat Sep 10, 2011 11:50 am
Is that how it is done on the x0xi0 and Devilfish? Has anyone done this sort of mod?
Syd
Postby Altitude » Sat Sep 10, 2011 7:20 pm
Brian has all the x0xio schematics on his website, check there
Altitude
Postby Syd » Sun Sep 11, 2011 1:02 am
ok, well upon further research I've learned that the "Accent Out" is a CV only mod. Apparently there's, currently, no such mod. Too bad as this would be a cool way to send your audio to different output. Although I'm still not sure if it's even possible; I may try looking into it further.
Syd
Return to x0xm0dz
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
