by bebo » Wed Sep 14, 2011 4:34 pm
Just assembled the i2c backpack and connected it to the 16x2 blue LCD [the one for $9.95, it says 1620A-17 on the part, couldn't find a part number on the invoice]. I downloaded the new LiquidCrystal library and tried the Hello World i2c sketch. The LCD lit up, and all that happened was the first row of pixels flashed, but no hello world. I followed the instructions on the website, but this LCD had two rows of 16 holes, one on the top of the LCD [as indicated by the up arrow] and one on the bottom. I soldered it to the bottom row, with the hole nearest the screw connector of the backpack on hole 16 of the LCD. In other words, if you are holding the backpack with the silkscreen lettering facing up, hole 1 of the LCD is on the left, and hole 16 is on the right. All the connections look sound, no cold joints or bridging, but I suspect maybe I should have soldered it to the other row of holes?? Soldered it the other way?? I would appreciate all insight and assistance......and Thank You Adafruit industries for the service you provide. It's pretty f***in remarkable what a hundred bucks can get you...
