Smallest AVR that's been Arduino bootloaded
Postby jmsaavedra » Mon Oct 10, 2011 9:46 pm
Hi all -
I'm working on a project that really only requires 1 ADC (8 or 10-bit) and 1 PWM pin (also 8 or 10-bit).
What's the smallest AVR microcontroller that you've seen bootloaded with Arduino? I ask this because I want it to be hackable afterwards by makers.
Otherwise are there any small AVR projects that are well documented out there? I have a USBtinyISP to get 'er done.
Any suggestions at all are hugely appreciated!
joe
jmsaavedra
Re: Smallest AVR that's been Arduino bootloaded
Postby westfw » Tue Oct 11, 2011 12:47 am
I think that the core and some of the libraries have been ported to AVRs as small as the ATtiny85.
http://code.google.com/p/arduino-tiny/
I don't think the tiny's support a bootloader.
Note that from a hackability point of view, a mega8 has compete Arduino compatibility, and is less than $1 more expensive than a tiny85...
(actually, a tiny85 isn't so tiny. 8k Flash! So it might be more capable than I'm thinking.)
westfw
Postby sircastor » Thu Oct 13, 2011 2:18 pm
IIRC from the 25/45/85, it does support a bootloader - I haven't spent any time seeing if the Arduino bootloader will fit on it. But as westfw mentioned, the ATtinyx5 will take Arduino compiled code. In fact, I did this just last night. I loaded my code with a programmer, but you can load it with an arduino, meaning you only need to write and compile and you're set.
The tinys don't need the Arduino boot loader - if you let the Arduino act as the programmer, you're gold.
sircastor
Postby kasbah » Wed Oct 19, 2011 8:03 am
In terms of package I think it is the atmega88s: http://jaanus.tech-thing.org/other/tiny ... e-possible
kasbah
Return to Microcontrollers
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
