Based on your experience, does the shipping labels (thermal printer based) fades before reaches it's destination?
It helps to reduce cost by removing the ink cost totally. Any thoughts?
48X24X48X wrote:Hi Guys,Based on your experience, does the shipping labels (thermal printer based) fades before reaches it's destination? It helps to reduce cost by removing the ink cost totally. Any thoughts?
48X24X48X wrote:Any recommended thermal printer? I thought of buying the Dymo LabelWriter 450.
neutron spin wrote:I use a Dymo LabelWriter 450 and it works well but there are others that are better. It depends on your shipping requirements basically. The more expensive units print larger labels and are more suited for commercial use. The Dymo is the most economical printer in the group. Dymo also makes dual printers to allows both stamps and label printing in one unit so you do not have to reload each time you switch between both types of printing jobs. Usually you get what you pay for but if your requirements fit the lower cost units that is great!
48X24X48X wrote:neutron spin wrote:I use a Dymo LabelWriter 450 and it works well but there are others that are better. It depends on your shipping requirements basically. The more expensive units print larger labels and are more suited for commercial use. The Dymo is the most economical printer in the group. Dymo also makes dual printers to allows both stamps and label printing in one unit so you do not have to reload each time you switch between both types of printing jobs. Usually you get what you pay for but if your requirements fit the lower cost units that is great!
Is there limitation on the address line? I saw some thin line stating *4 line address on their website.
