Monochron Pong Problems
Tick Tock Clock Kits
Postby JoeInAtlanta » Mon Oct 24, 2011 7:37 pm
Following is the issue I just sent by e-mail, which you requested I post on the forums.
I recently ordered and assembled the Monochron Pong Clock (Invoice 107859). The assembly went without a hitch, but now there are significant problems with the clock:
  1. There are “artifacts” – broken horizontal lines – on the display. When the ball moves over one of these spots, it disappears. But then is usually re-drawn nearby when the ball moves over a different spot.
  2. The time is perfectly accurate when it runs – even to the second. But then it gets stuck and fails to advance at all.
You can see both problems on the video linked here: http://www.youtube.com/watch?v=DsZL0tHuYpw (the video is over two minutes long, but the time never advances).
(Note that on the video it is difficult to see the ball at all – though you can easily tell where it is by the behavior of the paddles and the on-screen artifacts. This, however, is not an additional problem: In real life, while much dimmer than the paddles, the ball is easily perceived.)
And here is a still image of the screen:
I assembled the clock this past Friday evening with friends. They left and I went to bed shortly after finishing the project – and I noticed the display problems the first time I looked at the clock that next morning. I have found that I can re-start the time by re-setting it – but that fix is not permanent and the artifacts re-appear almost instantly.
I searched the forums to see if this was a known issue – but didn’t find any similar concerns. I did find an issue about vertical striping (http://forums.adafruit.com/viewtopic.php?f=41&t=22934&hilit=monochron+display), which I also noticed as soon as the clock was turned on. This vertical striping, alone, was not a deal-breaker for me – but the other issues definitely are.
What do we do about this? I would be satisfied with the purchase if it were behaving properly. But I am not at all satisfied as things currently stand.
Thank you for whatever assistance you can provide.
JoeInAtlanta
Re: Monochron Pong Problems
Postby adafruit » Mon Oct 24, 2011 7:45 pm
please post picture of the board assembly, front and back, the time problem sounds like the DS1307 or battery may not be soldered right
Postby JoeInAtlanta » Mon Oct 24, 2011 7:53 pm
I'll be happy to do that if necessary, but I won't be able to do so for a day or two.
Chasing down the clock malfunction, however, seems like a bit of a banned-chase. By e-mail you said it sounds like the screen is broken -- which strikes me as an issue that is (1) much more significant and (2) completely unrelated to the clock.
If you'll give me a preview into the next series of steps -- both in what you need from me and what I can expect -- it may help me to answer all of your questions, and you to answer all of mine, in a shorter series of messages.
JoeInAtlanta
Postby adafruit » Tue Oct 25, 2011 4:15 pm
thanks, we think there are -two- problems, the display and the clock time. the time is likely an issue with the DS1307/crystal/battery. the display may be a soldering issue or it might be the LCD module. both are very fixable, but we just want to check out your component placement to make sure!
Postby JoeInAtlanta » Tue Oct 25, 2011 7:53 pm
Okay, here are the pictures:
JoeInAtlanta
Postby adafruit_support_bill » Wed Oct 26, 2011 3:54 pm
Looks like you have everything in the right place. But some of the solder joints look a little 'cold' in the photo. Sometimes it is just the lighting, but if a joint has a rough or 'frosty' appearance, it usually means that the solder didn't flow properly. Using a clean, hot iron, re-flow any joints that don't look smooth and shiny.
Also, did you remember the blob of solder under the battery holder? A bad battery contact could explain erratic RTC behavior.
Postby JoeInAtlanta » Wed Oct 26, 2011 5:49 pm
Thanks. As for the blob under the battery, we definitely remembered that. The battery fits very snugly in its holder.
I'll check into the solder joints. A friend of mine with much better tools and much more experience (including building your x0xb0x project successfully) has promised to come over and re-solder questionable joins and generally look it over. (He was also here for the initial assembly of the Pong clock -- but we didn't have his tools at that time, and he let me do all the work to build my experience.)
Unfortunately, he is out of town until next week -- so I won't have an update for you until Tuesday at the earliest.
JoeInAtlanta
Postby JoeInAtlanta » Thu Nov 03, 2011 9:30 pm
Good news: It's working properly now.
My friend with better tools and more experience did indeed come over on Tuesday. He saw a few joins that looked questionable to him and went over them. We don't know exactly which one(s) might have been the culprit -- but the clock display is not showing the horizontal-line artifacts anymore, and it is keeping time properly.
I gave it 48 hours before posting this update, as the original problems didn't manifest themselves immediately -- but I've seen no sign of a problem now, so I'm optimistic that everything is good. (I'll follow-up, of course, if the problems recur.)
Thanks.
JoeInAtlanta
need help at the original pong clock
Postby adajobjob » Mon Jan 09, 2012 1:00 pm
Hi Forum,
I´m a happy first owner of one original pong clocks from 2006. The clock had worked perfect until yesterday. To clean the wall behind the clock i plugged it from power. After plugged it back on power the screen is now only flashing in an intervall of 1/2 second. Don`t know what i can do? Any help?
JJ
adajobjob
Postby adafruit » Mon Jan 09, 2012 1:08 pm
hiya!
we were not selling the MONOCHRON clocks in 2006. where did you purchase this from?
thanks,
Postby adajobjob » Mon Jan 09, 2012 2:35 pm
Hi adafruit, I´m one of the happy guys who got an "original" pong clock (number 62 from 400) back in 2006 (http://pongmuseum.com/history/_transfor ... gclock.php). And have no knowledge or idea to rescue it. So i searched via google and found your forum.
I know that this isn`t 100% the place for my clock and you are talking about your own mod. But maybe you can help me anyway
JJ
adajobjob
Postby adafruit » Mon Jan 09, 2012 2:43 pm
adajobjob wrote:Hi adafruit, I´m one of the happy guys who got an "original" pong clock (number 62 from 400) back in 2006 (http://pongmuseum.com/history/_transfor ... gclock.php). And have no knowledge or idea to rescue it. So i searched via google and found your forum.
JJ
thanks for posting, this isn't a product we made or support, we cannot assist you, sorry :(
thanks!
Postby adajobjob » Mon Jan 09, 2012 2:57 pm
This is not the answer i was hoping for :-(( But anyway thank you and best regards.
JJ
adajobjob
Return to Clocks
Users browsing this forum: No registered users and 3 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
