So I, like others it seems, am having a problem getting the drawdio working properly.
I picked up 6 kits to assemble for a 5th grade science class (they're doing stuff on sound and electricity, these are perfect for a demonstration/lesson). The schedule is currently to do this on thursday or friday.
Anyway, the problem.
I assembled 1 circuit. It is loud and clear when I touch the tabs.. but I can't get it to conduct through the pencil.
I haven't fully assembled it yet, but it should work at this point..
I attached the tape to the tab, checked that by touching it and the other tab.. works.
I attached the other end of that tape to the pencil via the pin into the lead (I shaved down the end of the pencil to verify I'm hitting directly into the graphite), but I can't get it to conduct through the pencil. I touch the other end of the pencil, nothing happens.
I have tried holding the sharp end of the pencil and touching the metal pin directly to the tab on the circuit, nothing. I have tried wrapping the copper tape around the head of the pin more to ensure a connection, nothing.
The pencil is the one that comes with the kit, with a 2b lead.
Any ideas? Obviously there is a weak link in my connection to the pencil somewhere.. but how best to find/fix it? Should I use a different setup/connection? I'm not opposed to using a different pencil or going out and buying whatever I need to make it work, but I'm on a bit of a time crunch. (I was going to buy fully assembled kits but they aren't in stock currently).
Any help would be greatly appreciated, I can provide pictures of any part if you think it'd help.
Kyle
