Can't bike fast enough?
SpokePOV kit for bikes
Re: Can't bike fast enough?
Postby Dave » Mon Jul 19, 2010 7:51 am
I just can't understand why this SpokePOV should work at a normal speed.
Granted, that we have a bike with 26 inches(66,04cm). So the circumference is 66,04cm*pi = 207cm. For the whole circle you need about 20 Hz.
That means the bike has to move with (2,07m*20) per second which is equivalent to 150km/h.
Postby adafruit » Tue Jul 20, 2010 3:59 pm
we put spokepovs on a bicycle with a odometer, and pedaled
Postby Dave » Fri Jul 30, 2010 12:49 pm
I still don't understand.
Can you just tell me what's wrong with the thoughts and calculations I did ?
Postby adafruit_support_bill » Fri Jul 30, 2010 1:20 pm
Not sure where this number comes from. Many 8mm movies were made at 16 fps. And you don't need even that rate for a static image.
The persistance of vision effect is subject to many variables ranging from image contrast and ambient lighting to the viewer.
Postby adafruit » Sat Jul 31, 2010 6:31 pm
Dave wrote:I still don't understand.
Since it has been tested to work at ~10mph, that would imply that your assumptions are wrong...you might be better off back-calculating from the known working speeds
Postby flipper » Mon Oct 25, 2010 8:10 pm
Dave calculations are correct
after tests, manually spinning a front mtb(26in) wheel will reach around 25km/h max, which around 3.3hz.
about as fast as someone cycling.
but the one thing special about LED pov is that they have a lot of "flash" power, and probably "burn" the pulse they send in human eyes.
Effect is pretty much like looking at the sun.
this add POV effect and enable us to see the whole picture. but cameras will obviously struggle capturing this, as they run at 24hz+
flipper
Postby AtomCore » Fri Oct 28, 2011 2:52 am
I have blur image on speed over 23km/h. Can HALL SENSOR have some limit, or send wrong signal to uC, or EEPROM is with high latency. My LED is Green High bright, maybe have voltage drop in high speed.
AtomCore
Postby adafruit_support_bill » Fri Oct 28, 2011 4:55 am
Make sure that the magnet is as close as possible to the sensor (without hitting it of course).
Previous
Return to SpokePOV
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
