Problem using VC0706 Camera w/ MEGA 2560
Re: Problem using VC0706 Camera w/ MEGA 2560
Postby wermet » Sun Oct 30, 2011 2:25 pm
That was one of the first things I checked, but I'll try it again just for completeness.
For simplicity, I'm going to use the MEGA 2560 without any other wiring (except the USB cable) connected. I am also going to use the "Blink" example sketch.
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
(1) Double checked that the correct board model (MEGA 2560) and com port (com 5) were being used.
(2) Complied, got the message "Binary sketch size: 1588 bytes (of a 258048 byte maximum)". Then waited for the "Done compiling" message.
(3) Then tried to upload. The message "Binary sketch size: 1588 bytes (of a 258048 byte maximum)" appears and then nothing. I waited over 5 minutes before ending the program.
(4) I then tried using a different computer, no joy either.
(5) I worked my way through the Arduino Troubleshooting (under Tools/Troubleshooting) without any joy.
(6) Then just to rule out that I wasn't doing something completely bone-headed, I tried using a bare Uno board (changed the Board type and Serial Port) and immediately had success.
So the bottom line is that I am completely stuck using the MEGA. :(
Thanks,
wermet
wermet
Postby adafruit_support_bill » Sun Oct 30, 2011 4:03 pm
Are you seeing any led activity during the upload attempt? Hold the shift key while pressing upload to get diagnostic output during the upload.
Postby wermet » Sun Oct 30, 2011 4:43 pm
I am getting no led activity. The diagnostic output from [shift]-upload is:
C:\Documents and Settings\wermet\My Documents\Arduino\Arduino\hardware/tools/avr/bin/avrdude -CC:\Documents and Settings\wermet\My Documents\Arduino\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -Uflash:w:C:\DOCUME~1\WERMET~1\LOCALS~1\Temp\build1224071311445986261.tmp\Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         System wide configuration file is "C:\Documents and Settings\wermet\My Documents\Arduino\Arduino\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM5
         Using Programmer      : stk500v2
         Overriding Baud Rate  : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: stk500_2_ReceiveMessage(): timeout
avrdude: Recv:
{snipped lots of repeating messages...}
avrdude: Recv:
{Note: I unplugged the USB cable at this point.}
avrdude: ser_send(): write error: sorry no info avail
Thanks,
wermet
wermet
Postby adafruit_support_bill » Sun Oct 30, 2011 4:58 pm
If the UNO works using the same port & cable, I'd suspect that maybe the 8U2 on the Mega 2650 is dead - although I don't know why the IDE doesn't time out on the upload.
Some have reported success re-flashing the 8U2 firmware to revive dead UNOs. I suspect the same is possible on the Mega. If you search the Arduino.cc forums you should be able to find details on that procedure.
Postby wermet » Sun Oct 30, 2011 10:05 pm
Success!!! :D
It turns out that all I had to do was to reset the 8U2 chip on the Arduino board. This is done simply enough by hooking up the USB cable to a computer and then shorting the leftmost two pins on the 2x3 connector immediately next to the Arduino's USB connector. I did not have to reflash the firmware or anything.
I found the information at http://arduino.cc/en/Hacking/DFUProgramming8U2 while searching for information on re-flashing the 8U2 chip's firmware.
Thanks for helping to point me in the right direction.
Sincerely,
wermet
wermet
Postby Miax » Tue Nov 01, 2011 6:50 am
If I may ask, by "using the hardware libraries", do you mean using Pin 0 and 1 on the Mega for communications?
I have a similar problem with Xbee's not working because NewSoftSerial isn't compatible with Mega 2560s, and I suspect I may need the same solution that you used with your camera..
Is there a quick description you could offer on how you used the hardware libraries?
Thanks!! :)
Kris
Miax
Postby ChuckA » Tue Dec 27, 2011 8:02 am
Did Wermet ever post his library for the Mega?
ChuckA
Previous
Users browsing this forum: No registered users and 9 guests
New Products [103]
LEDs[109]
Cables[61]
