SPOKE POV short circuit problem
SpokePOV kit for bikes
Postby Electrogeek » Tue Aug 30, 2011 8:25 am
i ve build an Spoke POV Kit with orange LEDs which dosent work as it should.
My problem is this, when i put in both batteries one batterie on the other end oppsite where the atmel is.
Gets very hot, so ive checked the batterie holders and i noticed a short circuit between plus and minus.
I looked at the solder connections but without any brigdes or cold solder joints.
Everthing looks fine.
So then ive connected an external dc power to the J1 joint with 3 V and it worked as it should.
My big question is now why is there a short circuit and is there any board layout shematic so i can follow the traces.
Besides i think the big electrolytic capacitor is wrong installed maybe can anybody check is out.
I hope the pictures are helping, i would be happy for every idea.
Thanks a lot
Electrogeek
Re: SPOKE POV short circuit problem
Postby adafruit_support_bill » Tue Aug 30, 2011 10:11 am
Make sure all the leads under the batteries are clipped and not shorting against the cell.
Postby zparker2000 » Tue Nov 29, 2011 7:25 pm
Have you been able to fix this? I have the exact problem and I'm sure the batter is not shorting against the leads.
zparker2000
Postby adafruit_support_bill » Wed Nov 30, 2011 6:24 am
What color LEDs? How many batteries are you using?
Postby zparker2000 » Wed Nov 30, 2011 7:53 am
Red w/ two battery's
zparker2000
Postby adafruit_support_bill » Wed Nov 30, 2011 8:27 am
Post photos of the front & back of the boards and we'll look for an assembly issues.
Postby zparker2000 » Wed Dec 07, 2011 6:42 pm
Here are pictures of the first side.
Zack
side a3.jpg (52.44 KiB) Viewed 2399 times
side a2.jpg (54.19 KiB) Viewed 2399 times
side a1.jpg (56.05 KiB) Viewed 2399 times
zparker2000
Postby zparker2000 » Wed Dec 07, 2011 6:43 pm
Here is the other side.
Zack
side b3.jpg (52.81 KiB) Viewed 2399 times
side b2.jpg (53.4 KiB) Viewed 2399 times
side b1.jpg (51.78 KiB) Viewed 2399 times
zparker2000
Postby zparker2000 » Wed Dec 07, 2011 6:45 pm
I've added a picture of a bare board with an ohm meter across the terminals of the bottom battery.
Zack
bare pcb.jpg (49.48 KiB) Viewed 2399 times
zparker2000
Postby adafruit_support_bill » Wed Dec 07, 2011 9:56 pm
I can't quite see your meter dial or where your probes are contacting. But are you seeing 0.3 ohms between the unpopulated positive and negative battery terminals?
Postby zparker2000 » Wed Dec 07, 2011 10:52 pm
Yes, 0.3 ohms with the leads are connected to the pos and neg terminals of the bottom battery.
Zack
zparker2000
Postby adafruit_support_bill » Thu Dec 08, 2011 5:47 am
Does the built-up board measure about the same? (without batteries installed)
Postby zparker2000 » Thu Dec 08, 2011 5:55 pm
Yes... 0.5 ohms
zparker2000
Postby adafruit_support_bill » Thu Dec 08, 2011 6:22 pm
You are using the 1st and 3rd battery locations. The 3rd one is only needed for higher voltage leds like the blue ones. You should be using the 1st and 2nd batter locations as in the photo:
Postby zparker2000 » Fri Dec 09, 2011 8:49 am
That was it... I put the battery in the wrong spot. It works now thanks
Zack
zparker2000
Return to SpokePOV
New Products [102]
LEDs[109]
Cables[60]
