High voltage on the j4 section
Re: High voltage on the j4 section
Postby j'ke » Sun Dec 11, 2011 2:47 pm
When i put the ground on C20 i get my 5,33v back and on the other 25v (but this should be 12v).
When i probe the middle pin on J4 for ground i get nothing. But it can be due the fact of a banned multimeter i realize now :)
j'ke
Postby guest » Sun Dec 11, 2011 2:55 pm
im sorry
i spoke too soon on my last post
r178 or ic23 is not soldered in well
check the resistance between pin2 of ic23
and one end of r178
and then do the same for pin1 of ic23
if it all seems to be connected
then ic23 is bad
guest
Postby guest » Sun Dec 11, 2011 2:56 pm
perhaps easier to do
is to measure the resistance
between pins1 and 2
make sure the power is off
guest
Postby j'ke » Sun Dec 11, 2011 3:05 pm
When i test Pin2 of the IC to the near pin of R178 i get 0,0 ohm, when i do this on the far pin of the R178 i get 2,2k
And with pin1 of the IC it is just the other way around but with the same values. One pin 0v other pin 2.2k
And again thx for your effort, you rule!! :)
j'ke
Postby j'ke » Sun Dec 11, 2011 3:06 pm
guest wrote:perhaps easier to do
between pins1 and 2
This is 2.2 k
j'ke
Postby guest » Sun Dec 11, 2011 3:14 pm
sorry to say
ic23 is bad
the only other thing you can try
is to remeasure the voltages on ic23
but make sure you take them from the top of the chip
so youre actually touching the legs to the chip itself
guest
Postby j'ke » Sun Dec 11, 2011 3:22 pm
I get nothing now. :)
So if i put in a new IC, is there anything i can test before soldering it in? Like there should be no resistance value between pin1 and pin2?
j'ke
Postby guest » Sun Dec 11, 2011 3:27 pm
do you mean there are no voltages?
or that nothing has changed?
you should see the same voltages as before
and the same resistance between pin1 and pin2
if you do not
then the chip just needs to be soldered in better
guest
Postby guest » Sun Dec 11, 2011 3:30 pm
if all the voltages and resistances are the same
when you measure directly on the ic pins
then you can just put a new opamp in
and it should work
guest
Postby j'ke » Sun Dec 11, 2011 3:36 pm
The first one, i get no voltage anymore. Only pin 5 has the same 5.5v.
Even pin 8 has no more 27,5v but R1 has.
The resistance is still 2.2k between pin 1 and pin2.
So you think is just soldered bad?
j'ke
Postby j'ke » Sun Dec 11, 2011 3:49 pm
pffff i think my multimeter broke down, now i get the same voltages on all the pins of the IC.
So i will try a new one.
Thx for your help, really appreciate it a lot!!!!
j'ke
Postby j'ke » Sun Dec 11, 2011 3:59 pm
Woopwoop, i resoldered it, and now i get to right values!! :)
Acid here we come. Thx mysterious guest for the effort!!
j'ke
Postby guest » Sun Dec 11, 2011 11:57 pm
congrats
guest
Previous
Return to Making x0x
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
