Tweet-a-watt issue: display on kill-a-watt cycling off and on
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
Postby dd1968 » Sun Jan 08, 2012 7:58 pm
After modifying a Kill-A-Watt with the Tweet-A-Watt kit I encountered an issue where the display on the Kill-A-Watt would not come on and stay on. The K-A-W display would flicker to life but when the green light blinked the display would go off and the K-A-W would reset. The assembly instructions indicated that it might take 30 seconds or so for the K-A-W to settle down but mine didn't, even after a few minutes.
I came to the forums and found two threads that seemed to speak to this issue. In both cases the adafruit-support answer was to increase the delay on the transmitter side. I wanted to share my experience here with a resolution in case it might help the next person...
In my case the issue was not the transmitter delay setting but the fact that I hadn't configured the transmitter, period. I got ahead of myself and, after assembling all the hardware, I plugged In the K-A-W. The steps for assembly are NOT "build the receiver, build the transmitter, plug it in" but, significantly, "build the receiver, "CONFIGURE, build the transmitter".
The link to the "configure" step:
[http://www.ladyada.net/make/tweetawatt/config.html]
I have a feeling that others have made the same mistake that I made or will do so. I am more than happy to admit that in my haste I missed an entire step.
Once the transmitter was configured I had no more trouble with the K-A-W display...it settled down within about 30 seconds.
A note about configuration of the transmitter: the instructions say that (in the terminal software) you need to get the modem's attention by waiting ten seconds then typing +++ quickly. That "quickly" part escaped me at first and I had a hard time figuring out why the modem wouldn't respond. Eventually I figured out that "quickly" is the key word in that instruction. Typing +++ QUICKLY did the trick.
dd1968
Re: Tweet-a-watt issue: display on kill-a-watt cycling off and on
Postby adafruit_support_bill » Mon Jan 09, 2012 5:56 am
Thanks for the follow-up. We'll keep that in mind when others post with the same symptoms. :)
Return to XBee products from Adafruit
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
