Item 491 - Illuminated Pushbutton
Postby Satellites » Mon Jan 16, 2012 2:37 pm
The LEDs on this item takes a 5v source?
Thanks,
Erik
Satellites
Re: Item 491 - Illuminated Pushbutton
Postby adafruit » Mon Jan 16, 2012 3:03 pm
yes
they are an LED, so you will want to put a resistor in series, 5V shoudl work fine. use a LED resistor calculator to determine what resistor value you need
Postby Satellites » Thu Jan 19, 2012 4:00 pm
What size connectors will work best on this item, 4.8mm or 6.3mm?
Satellites
Postby Satellites » Thu Jan 26, 2012 3:22 am
ugh... you need a better method for customer service.
Satellites
Postby adafruit » Thu Jan 26, 2012 11:51 am
hi Satellites, you posted a question at 4PM and we responded at 5:45PM a week ago requesting more information. We would like to help you but its unclear what you mean by "connectors" - the button has to have a hole drilled to connect it to a plate and that hole is 16mm diameter. but it seems you might be asking about something else. if you can post a detailed question we can give you a detailed answer but we don't know what you're asking about in specific. Please give us some more information so we can help you out!
Users browsing this forum: Google [Bot], yigangfang and 5 guests
New Products [103]
LEDs[109]
Cables[61]
