Hi All...
I am trying to build a board with a super capacitor that will keep it up for several seconds after the power goes away. This is because the device is logging data to an SD card and I need to detect that power went away, and then close the files on the SD card gracefully. I am thinking a super cap will hold my board up for a second or so, giving me time to close the files.
But, after lots of googling, I have not learned much. My device accepts 12V to 14.7V in and uses a 5V regulator to make 5V. Some of the board uses 5V and there is also a 3.3V regulator for the SD card, which needs 3.3V. So there is 12V in to a 5V regulator which then feeds a 3.3V regulator.
I did see that I should use a 5.5V cap down stream of the 5V regulator and upstream of the 3.3V regulator, because super caps don't come in much higher voltages. If I needed to put the cap on the 12V line then I would have to string caps together which reduces their capacity.
But I don't know how to figure out the value of the cap that is needed based upon current draw and how much time I want to stay up.
Any help?
Thanks...
