Quick question ref C101
Postby safetyboy » Mon Jan 09, 2012 5:11 pm
My friend bought a x0x off someone and it was working fine, he then tried to flash with sokkos FW but it's stopped working now, I've tried to re-flash it with original x0x FW but its still not working, So i got a stand alone programmer and re flashed the micro-controller which all goes fine, but still nothing from the x0x. The odd LED will light up when plugged in but that's it.
I noticed that there is no cap in c101, could this cause trouble?
safetyboy
Re: Quick question ref C101
Postby guest » Mon Jan 09, 2012 7:41 pm
you should definitely put c101 in
and if your standalone programmer can do it
check what the fuse settings are in the x0x
im guessing it has something to do with the bootloader
guest
Postby safetyboy » Tue Jan 10, 2012 4:10 am
Cheers will check that when i get home.
* How do I check the fuses and the bootloader :)
c0ntr0l uploaded the FW fine, but still no joy, tried the patched c0ntr0l and now neither c0ntr0l works! meh?! :cry: :cry: :cry: :evil: :evil: :evil: :twisted: :twisted: :twisted:
every time i try run control now i get this error
If i go the the resources folder and double click sixteenth.gif it opens Internet explorer, strange..
safetyboy
Postby safetyboy » Sat Jan 14, 2012 1:35 pm
anyone?
safetyboy
Postby guest » Sun Jan 15, 2012 4:22 am
i dont know how control works at all
what programmer are you using
guest
Postby safetyboy » Sun Jan 15, 2012 7:38 am
http://www.advin.com/eprom-programmer-580A.htm
this one here, it was working fine before trying new FW so I assume all is fine up until the Seq! I have an oscilloscope that i will try collect today and work my way through it!
safetyboy
Postby guest » Mon Jan 16, 2012 9:56 am
if you have a scope
check that the crystal is oscillating
and then see if there is any data going on any of the lines
i havent seen that programmer before
are you using it with avrdude
guest
Postby safetyboy » Thu Jan 26, 2012 1:49 pm
anyone know where this board came from?
safetyboy
Postby guest » Thu Jan 26, 2012 3:13 pm
looks like a modemachines/tt x0x
although its hard to say without seeing the whole thing
but they use the small resistors like that
and the switch pcb layout is different
if it doesnt say who made it on it
thats not a good sign
guest
Postby safetyboy » Thu Jan 26, 2012 4:58 pm
any use? i seem to have good voltage around the board on all the IC's, as i said, it was working before the USB flash?
Any idea's guest?
It is different from my board from x0xsh0p which worked and flashed perfectly.
Crystal seems to be oscillating, I only got the scope last night so i am a bit confused with it. left pin on the xtal
safetyboy
Postby guest » Thu Jan 26, 2012 5:22 pm
definitely a tt kit
its got the chip resistors in there for r100
what frequency is the sinewave on the scope you show
are there any signals
on any of the other pins of the microcontroller
guest
Postby safetyboy » Thu Jan 26, 2012 5:49 pm
Not sure as i was just given the scope today, My electronics are before this techno banned :) Everything seems fine on the voltage front, so i assume its the bootloader you speak of, would ordering a new Microprocessor work or is it fixable?
Edit :
So its a TT, what's the easiest way of fixing this bad boy?
safetyboy
Postby guest » Thu Jan 26, 2012 8:02 pm
check that there is 5v
on pins 9 and 40 of the microcontroller
then double check the scope on the xtl pins
and see what the amplitude and frequency are
if youre not certain how to read those
post a clear screen shot
check with the scope to see if there are any other signals
or are they just fixed at 5v or ground
getting a new microcontroller is probably the easiest fix
but we should be able to get this running
although it might require reburning the micro
guest
Postby safetyboy » Fri Jan 27, 2012 10:34 am
IF i put the microprocessor in my working x0x and program it there will that work?
safetyboy
Postby guest » Fri Jan 27, 2012 11:02 am
you should put the nonworking microcontroller
into the working x0x and see what happens
just to verify that its the microcontroller thats broken
and you can try to program it in the working x0x
it might not work though
guest
Next
Return to Making x0x
Users browsing this forum: Google [Bot] and 4 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
