LCD help?
LCD help?
Postby thekiller578 » Wed Feb 01, 2012 2:45 am
Hi guys, i just need to know if it possible to hook up an LCD screen from an old laptop,
ive seen some small LCDs work but those are small,
i have a pic also if it helps anyone,
screen specs are 9" 11/16 x 7" 1/4
thekiller578
Re: LCD help?
Postby jtigchelaar » Wed Feb 01, 2012 7:30 am
The Arduino in itself is not capable of driving an LCD screen of that size or color depth.
There are boards such as the gameshield and some boards from sparkfun that can drive a VGA monitor, but all are limited to low resolution.
Driving this specific LCD screen would be possible if you knew the pinout of the ribbincable, some will be power, others should match the VGA signal lines, it will however be very hard to figure out if you don't have a datasheet.
If your goal is to drive big VGA LCD screens, berhaps you should look into the somewhat more powerfull SoC boards such as the MINI2440 ARM boards (http://www.thaieasyelec.net/index.php/SBC-/-Embedded-OS/mini2440-TFT-3-5-inch-Touch-Screen-S3C2440-ARM9-Development-Board-1-GB-NAND-FLASH-/p_182.html)
jtigchelaar
Re: LCD help?
Postby thekiller578 » Wed Feb 01, 2012 3:24 pm
thank you for that, i just was not sure if anyone ever tried,
or the reason why it couldn't be done :P
thekiller578
Return to Arduino
Users browsing this forum: No registered users and 8 guests
New Products [102]
LEDs[109]
Cables[60]
