Burn fuse Walkthrough REQUEST??
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
Re: programming verification
Postby Eno » Sat Apr 21, 2007 12:12 am
hahahehihoha wrote:Using a new AVR ISP MKII. Using ATmega88:
In AVR studio:
BOARD TAB:
125 kHz ISP frequency (tried others before)
FUSES TAB:
The SPI serial program downloading is unchecked and has a question mark.
everything OK except it says "entering programming mode...failed"
ISP mode error dialog box:
~check frequency of ISP...
I try programming, but verification not pass one address is bad, after
that Atmega don't go to programming mode.
What to do?
I have the same problem, but I was using 1MHz, I missed the "it has to be 1/4 of 1MHz". I kept on having the error: "Warning, verification has failed" or something to that effect. Will try again tomorrow.
Eno
question
Postby none_such » Sat Apr 21, 2007 11:54 am
check that the orientation of the microconrroller chip is correct; also, as usual, check for bridges - you both are encountering chip problems, not other hardware or programming problems.
hahahehihoha - I thought you gave up and went surfing.
Cheers
none_such
Postby Eno » Sat Apr 21, 2007 4:57 pm
I think my verification problem was because I set my speed to 1MHz. I'll try it later with a different speed.
Eno
Postby none_such » Mon Apr 23, 2007 5:46 am
Eno,
You should still be able to use 1 mhz if you deselect divide by 8 internally from the fuses section , but first you need to communicate with the micoprocessor first - change that fuse setting at 125 khz then you can choose the higher freq. If you can't there is some other problem.
none_such
continuing silly
Postby hahahehihoha » Tue Apr 24, 2007 6:03 pm
Chapter 7 in the ATMEGA88 PDF is about syst3m clocks and clock sources.
7.2.1 Default Clock Source
The device is shipped with internal RC oscillator at 8.0MHz and with the fuse CKDIV8 programmed, resulting in 1.0MHz system clock.
ok, less than 1/4th is under 250kHz, I use 125kHz and it doesn't work.
hahahehihoha
Postby none_such » Tue Apr 24, 2007 10:20 pm
hahahehihoha-
have you tried removing the microcontroller with hot air; inspecting pins and pads; double checking orientation (when reading "Atmel" on the chip, "Wave Bubble ..." on PCB should appear upside down) and remounting? If so, try a new microcontroller. If you get the same results after that, I don't know what to tell you: God is just trying to tell you something like, "You do not need a cell phone jammer."
none_such
Re: continuing silly
Postby Eno » Tue Apr 24, 2007 10:28 pm
hahahehihoha wrote:Chapter 7 in the ATMEGA88 PDF is about syst3m clocks and clock sources.
I used 125kHz. It seems to have worked(all tests say "O.K."). But I am waiting on parts to continue building. Please explain what errors you had.
Eno
Previous
Return to Wave Bubble
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
