uln2803a amps?
uln2803a amps?
Postby ingre_dients » Fri Feb 10, 2012 5:43 pm
Any idea how many amps I can take through the uln2803a? I can't figure it out exactly. I have a few brushless motors I want to turn on and off for (delay 60 or 100) or so, and since they are connected to something heavy they pull about 1 amp and sometimes more. Do you think this is too much? The motor shield seems to only do 1.2amps max. Any suggestions?
ingre_dients
Re: uln2803a amps?
Postby philba » Fri Feb 10, 2012 8:04 pm
when in doubt, read the datasheet. http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000179.pdf
In this case you are looking for continuous collector current - Ic, 500 mA
philba
Re: uln2803a amps?
Postby ingre_dients » Sat Feb 11, 2012 10:21 am
Thanks for your reply. I tried reading the data sheet but I'm fairly new to all of this and don't really know what most of it means.
With small pulses of around 700-1amp do you think it would be ok? Not a continuous current. It hasn't gotten hot or anything after many hours operation.
ingre_dients
Re: uln2803a amps?
Postby ingre_dients » Sat Feb 11, 2012 10:35 am
Oh I just saw that I could parallel the outputs for higher current. Please excuse the novice question here, but would that just mean putting a few of the outputs going to the same wire, then having the wire extend to the motor? Also, would I have to change the code to turn on the outputs at the same time or something? Any input would help a great deal, thanks a lot.
ingre_dients
Re: uln2803a amps?
Postby ingre_dients » Sat Feb 11, 2012 11:03 am
sorry just realized I could just buy a regulated 500Ma supply at the right voltage, instead of this massive 5 amp supply!
ingre_dients
Return to General Project help
Users browsing this forum: Zener and 9 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
