jeffrey1790 wrote:pburgess wrote:jeffrey1790 wrote:the brightness of my adalight setup seems very dim. is there a way to increase the brightness, but have the colors still change between scenes?
How close is your monitor to the wall? For the Adalight LEDs, ideally this should be about 6 inches, or maybe even a little less. Also, a dark room helps, obviously. How dim are we talking?
the monitor is about 1/2ft away from the wall since its on one of those hybrid stands. if i change the mode from ambilight to backlight, and increase the brightness to 100%, they appear to be really bright.
Alternatively maybe You should brighten the video (not best idea, I know) in Your player or decoder (like ffdshow). Just to get closer to the root of the problem.
OR drive gamma down in lightpack (gonna loose colors)
OR play with the minimum level of sens.
(both in expert mode)
