USB Dongle fail to comunicate with SpokePOV
Re: USB Dongle fail to comunicate with SpokePOV
Postby adafruit » Wed Feb 15, 2012 12:21 pm
remove the spokepov batteries, insert the USBtiny jumper
try the test
Postby tony18183 » Wed Feb 15, 2012 8:25 pm
Failed
tony18183
Postby tony18183 » Thu Feb 16, 2012 10:00 am
With Jumper Install
tony18183
Postby adafruit » Thu Feb 16, 2012 3:32 pm
OK please post up photos of the spokepov PCB, and the top & bottom of the usbtiny - something is loose
Postby tony18183 » Thu Feb 16, 2012 11:38 pm
tony18183
Postby adafruit_support_bill » Fri Feb 17, 2012 6:21 am
Looks like a few cold joints there. Using a clean hot iron, re-touch any solder joints that are not smooth and shiny.
Also, where the solder has balled up around the pin, it often has not properly wetted the pad. Re-touch those to make sure that the solder has flowed well onto both the pin and the pad.
Postby tony18183 » Fri Feb 17, 2012 10:02 am
I cant spot any more cold joint on the USBtiny except where the USB connecter mechanical tab.
tony18183
Postby tony18183 » Sat Feb 18, 2012 5:06 am
Finally, I got connection. I wonder why got connection even tho the dongle didnt pass the test?
havent try to write image yet so no sure the dongle fully working.
tony18183
Postby tony18183 » Sat Feb 18, 2012 7:01 am
Now having problem installing the magnet to the frame. How to install it within 1 cm close to the sensor? if > 1cm, the LEDs not blink.
tony18183
Postby adafruit » Sat Feb 18, 2012 5:09 pm
use some sort of spacer, a visit to your local hardware store will probably help you find a few options!
Previous
Return to USBtinyISP
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
cron
