Hi there,
After completing my previous xoxbox (thanks for all the help on here, especially to guest of course) I decided I'd like to build another one for a friend.
Wouldn't you know it I've ran into a problem straight off the bat.
I've gone through the first section and having placed all the components I've had a strange problem where by my power supply has stopped working. (The actual AC adaptor)
I measured the Voltage at the input and was getting nothing.
Measured across C3 (VAC I think) and got 30VAC. Thought that was odd measured across C5 and got nothing. Changed multimeter to DC and measured again and got nothing on both caps.
I very briefly got 5.2v off pin 5 on the IC. But that started slowly climbing down and down.
Oddly however I was curious as to why there was no power so tried measuring the voltage of the AC adaptor itself and got nothing. Thinking something was wrong I measured the AC adaptor of my other xox AC adaptor and that was working fine so I plugged that in to see if I got any measurements but still couldn't get anything.
I then unplugged the second AC adaptor and lo and behold that AC adaptor was also 'broken' now.
Is there any way that the AC adaptors could break plugging them into the I/O board? I've literally only put in the first sections components and am flabbergasted as to how the AC adaptors could have broken?
I've double checked all components to make sure all the capacitors and diodes have been put in the correct way etc..
It's just so strange how both AC adaptors now don't work, leaving me in the dark to test further...
