Hi there,
I'm wondering if anyone has some advice troubleshooting a volume problem with a willyzx kit that I've built.
Specifically everything seems to be working normally, except that the volume is very low coming from both the headphone and mix outputs.
I've checked the voltages on the ba6110 thinking that might be the problem (I assume its the amp chip). The readings VDC readings that I got on each pin were very similar to the ones the testing faq said to expect:
pin 1: 5.3v
pin 2: 5.3v
pin 3: 0v
pin 4: 0v
pin 5: 0v
pin 6: 5.03 (should be 5.3v)
pin 7: 5.03 (should be 5.3v)
pin 8: 5.34
pin 9: 11.89
The VAC readings however were vastly different than the expected values noted in the faq
pin 1: 10.7v (should be 10mv)
pin 2: 10.7v (should be 0mv)
pin 3: 0v (should be 0mv)
pin 4: 0v (should be 1.2v)
pin 5: 0v (should be 0mv)
pin 6: 9.7v (should be 750mv)
pin 7: 9.7v (should be 750mv)
pin 8: 10.9v (should be 750mv)
pin 9: 25.3v (should be 0v)
Does anyone have any idea what problem this would indicate, besides a shot ba6110?
Thanks.
