Convert unsigned int to 2 unsigned char, upper and lower
Postby Zener » Sun Feb 26, 2012 7:27 pm
In C, is there an easy way to do this? I am hoping yes...
Zener
Re: Convert unsigned int to 2 unsigned char, upper and lower
Postby franklin97355 » Sun Feb 26, 2012 9:34 pm
Try "anding" with 0xf and then shift right 8.
franklin97355
Postby hjohnson » Sun Feb 26, 2012 10:51 pm
This should work.
#define LOW_BYTE(x) = (x & 0xFF) //just the lower byte
#define HIGH_BYTE(x) = (x>>8) & 0xFF //make the higher byte the lower byte, then take just it.
See: http://www.arduino.cc/playground/Code/BitMath
hjohnson
Postby philba » Mon Feb 27, 2012 5:31 pm
The shift and mask thing is pretty much the standard way of doing it. A bit faster in that it does no shifting or masking. (Not a big deal unless it inside a loop).
int a;
char *alow = (char *)&a;
char *ahigh = (char *) &a+1;
void setup(){
    a = 0x0102;
    Serial.begin(9600);
    Serial.println((int)*ahigh);
    Serial.println((int)*alow);
void loop(){}
prints out
1
2
philba
Postby Zener » Mon Feb 27, 2012 7:33 pm
Yep, simple. Did this:
unsigned int address = 0xBBAA;
unsigned char adrhigh = 0;
unsigned char adrlow = 0;
adrlow = address & 0xFF;
adrhigh = (address>>8) & 0xFF;
Works. I just wasn't sure the compiler would like me mixing types like that...
Zener
Return to Microcontrollers
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
