2.8" TFT LCD Library Error fillTriangle
Postby owendelong » Mon Feb 13, 2012 1:41 pm
The fillTriangle function is buggy and will (for some values of angle (i) in the following) fill nearly the whole screen instead of just the area intended.
Specifically, 8 seconds (48º) to 12 seconds (72º) will reliably break.
Less critical, but, also annoying, the two halves sometimes have some pixels in between them which are not drawn.
I have not tested whether a drawLine up the middle would work around the missing pixel issue or not.
Code to reproduce problem:
#include <TFTLCD.h>
// Modify as needed for your configuration
#define LCD_RESET A4
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_BL 8 // To Backlight Control Transistor
#define FACECENTRX 63
#define FACECENTRY 63
TFTLCD lcd(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// This should initialize the display and draw a diamond shaped hand rotating around the dial ala a second hand on a clock.
// This example is reduced from an actual clock application to the minimum necessary to replicate the library bug
void setup()
lcd.reset();
lcd.initDisplay();
lcd.fillScreen(lcd.Color565(0,0,0));
lcd.setRotation(2);
pinMode(LCD_BL, OUTPUT);
digitalWrite(LCD_BL, HIGH);
int i;
while (1)
for(i=0; i<360; i+=6)
drawHand(lcd, i, 46, 255,255,255, 10);
delay(1000);
drawHand(lcd, i, 46, 0, 0, 0, 10);
void drawHand(TFTLCD D2, int a, int d, byte r, byte g, byte b, int width)
float c,w, z;
int dh_x2, dh_y2;
int dh_x1, dh_y1;
unsigned int co;
float rad;
co=D2.Color565(r,g,b);
c = ((a+270)%360); // orient correctly
z = c = c * PI/180;
// Draw hands as polygons (fast)
dh_x1 = cos(c)*d+FACECENTRX; dh_y1 = sin(c)*d+FACECENTRY; // tip of hand
w=width*PI/180;
c -= w/2; // Widen (go counterclockwise w/2 radians (== width/2 degrees)
rad = d*(d<40 ? 0.6 : 0.8);
dh_x2 = cos(c)*rad+FACECENTRX; dh_y2 = sin(c)*rad+FACECENTRY; // Counterclockwise wide point
D2.fillTriangle(FACECENTRX, FACECENTRY, dh_x1, dh_y1, dh_x2, dh_y2, D2.Color565(r, g, b)); // Draw counterclockwise half of hand
c += w; // Widen other direction (clockwise w radians == width degrees from counterclockwise edge)
dh_x2 = cos(c)*rad+FACECENTRX; dh_y2 = sin(c)*rad+FACECENTRY; // Colckwise wide point
D2.fillTriangle(FACECENTRX, FACECENTRY, dh_x1, dh_y1, dh_x2, dh_y2, D2.Color565(r, g, b)); // Draw clockwise half of hand
void loop()
owendelong
Re: 2.8" TFT LCD Library Error fillTriangle
Postby adafruit » Mon Feb 13, 2012 1:55 pm
Can you post an issue to the github repo? that would be most helpful!
Postby owendelong » Mon Feb 13, 2012 2:37 pm
OK... Issue created. It's currently the only open issue on the library.
owendelong
Postby stimps » Thu Feb 16, 2012 8:49 am
Has anyone worked out what is going on with this?
I have had the same problem, with it filling the whole screen sometimes, getting away with it so i can finish the project, by keeping all three points of the triangle on a different x axis.
No fix for it yet?
stimps
Postby owendelong » Fri Feb 17, 2012 2:16 pm
Nothing from adafruit here and nothing on the issue at github so far.
I could really use a fix as well.
I'll have to investigate the x1/x2/x3 equivalence you describe. I hadn't put that much information together about the problem, but, if that's the case, that's a strong clue and I might end up trying to debug this myself. Unfortunately, my knowledge of the math involved in efficiently filling a triangle is less than minimal, so debugging someone else's algorithm for doing so will likely be a learning experience beyond what I was hoping for.
owendelong
Postby adafruit » Sat Feb 18, 2012 5:05 pm
we have a long list of fixes to go thru, we'll get to this as soon as we can, but there is no ETA on when the fix will be pushed
Postby owendelong » Sun Feb 19, 2012 4:10 pm
Understood. I'll continue to look at it. I found a little bit more detail:
I've narrowed this down a little bit more.
The problem seems to occur when (after sorting the coordinate pairs such that y0<=y1<=y2, you are left with a case where x0<x2<x1.
It does not seem to matter whether or not any of the x values are equal or whether or not any of the y values are equal.
I'm continuing to work on figuring out a fix.
(also posted to github).
If I get a fix before you guys get to it, I'll post diffs here and on github.
owendelong
Postby owendelong » Sun Feb 19, 2012 5:43 pm
Resolved...
Here's the deal... Sometimes the algorithm passes to drawHorizontalLine a value where x1>x2. This results in a line width being passed to drawHorizontalLine which is a negative signed long int. drawHorizontalLine expects an unsigned 16 bit integer.
Solution: reorder the arguments to drawHorizontalLine and reverse the computation for the width of the line when necessary.
Essentially replace occurrences of:
      drawHorizontalLine(sx1/1000, sy, (sx2-sx1)/1000, color);
With:
      if (sx2 < sx1)
        drawHorizontalLine(sx2/1000, sy, (sx1-sx2)/1000, color);
      else
Hopefully when you guys merge this into the library, you can also merge in my improvements to drawChar.
owendelong
Postby adafruit » Mon Feb 20, 2012 4:18 pm
owendelong, please email support@adafruit.com if/when you see this - we have a special gift for you :)
cheers,
adafruit support, phil
Postby owendelong » Sat Feb 25, 2012 11:23 pm
There are still some funky results from some triangles in my further testing, but, at least it doesn't run off and cover the whole screen.
It's working well enough that I probably won't get back to messing with it.
owendelong
Postby owendelong » Mon Mar 05, 2012 11:52 pm
Interestingly, while I didn't change the code in the fillTriangle routine in the Max32 port I just did, the strange graphical artifacts disappeared on the Max32.
As such, I suspect it may be a math problem or rounding error on the AVR that is responsible.The PIC is definitely a WHOLE lot faster than the AVR ATMega2560.
owendelong
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
New Products [102]
LEDs[109]
Cables[60]
