12mm RGB LED Pixels strand - length
Postby watss » Tue Mar 06, 2012 9:46 am
What is exact length of wires between 2 leds in these strips:
12mm Diffused Thin Digital RGB LED Pixels (Strand of 25) - WS2801
http://www.adafruit.com/products/322
12mm Diffused Flat Digital RGB LED Pixels (Strand of 25) - WS2801
http://www.adafruit.com/products/738
I want to use these strips to make Adalight on 42" flat screen
and I need to know if 25 pixels would be enough :)
watss
Re: 12mm RGB LED Pixels strand - length
Postby adafruit » Tue Mar 06, 2012 10:41 am
center to center, or from pixel edges
Postby swissarmy » Tue Mar 06, 2012 12:29 pm
If I were you I would take 50 leds.
50 leds / 40" lcd
http://www.youtube.com/watch?v=sIRTkZ6eZ2Y
25 leds / 40" lcd
http://www.youtube.com/watch?v=9WUfdrF9KmI
It's my tv, I've made a test and turned off every other led to see a result.
For 42" you need 50 leds unless you don't want to light bottom of your tv, then 25 leds might be enough.
swissarmy
Postby watss » Tue Mar 06, 2012 3:12 pm
@adafruit: center to center
also I'd like to know how long 9-pixels strand can be stretched
@swissarmy: thanks for your videos
50-leds looks much smoother, but I'm short on cash ;)
watss
Postby pburgess » Tue Mar 06, 2012 4:59 pm
For the 'thin' type: about 4 inches or 10 cm center-to-center. Maybe a tiny bit more if really taut. 9 pixels will reach 32" or 80 cm.
For the 'flat' type: about 4.5 inches or 11 cm, again with a tiny bit of slack. 9 pixels = 36" or 90 cm.
pburgess
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: No registered users and 8 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
