Help Identify This Mystery Display!
Postby ryanrockey » Tue Mar 06, 2012 2:59 pm
I picked up two of these displays at a salvage store. It looks like a display of some kind. 3x7 LED with 12 pins.
I have attached a few images from all sides.
Thanks for any help with tracking down how to use these.
IMG_0417 (1).jpg (775.28 KiB) Viewed 478 times
IMG_0418 (1).jpg (609.99 KiB) Viewed 478 times
IMG_0419 (1).jpg (288.45 KiB) Viewed 478 times
ryanrockey
Re: Help Identify This Mystery Display!
Postby philba » Tue Mar 06, 2012 5:21 pm
My guess is it's a simple matrix. I'd start doing continuity checks between each pair of pins. Or, you could get a 5V source with a series 330 ohm resistor and see what pairs cause what to light up.
philba
Postby ryanrockey » Tue Mar 06, 2012 6:47 pm
By series resistor: 1 330 ohm on whatever pin I test as GND or a resistor on each input pin but not on GND?
This is my first try at black box testing a component and would love some advice or links about general testing methods.
Thanks for your help.
ryanrockey
Postby philba » Tue Mar 06, 2012 10:08 pm
It doesn't matter whether you run the resistor from gnd or +5. You are just trying to make a connection that will illuminate a segment. If nothing illuminates on your first two pins, reverse the connections. It shouldn't take long to "buzz" them all out. It might help to have a mirror so you can see both the pins and the display at the same time.
philba
Postby Zener » Wed Mar 07, 2012 8:01 pm
Looks like a simple 3x7 matrix organization.
Zener
Users browsing this forum: mibignistinly and 6 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
