Adalight not showing right colors
Postby sjaok » Thu Mar 08, 2012 3:01 pm
I have a Arduino Uno 3 and the WS2801 led strand.
The problem is that they don't show right colors, just pink/purple-ish all the time..
The leds only change the color slightly, all colors shown are purple og pink mostly.
(It just dim the purple color up and down as the screen changes) :?
They don't turn off when there is a black spot where the leds capture on the screen either.
I have tried the Adalight-code but are now using Ligthpack.
Is the problem on the Arduino board or in the sourcecode?
Do anyone have a fix for this?
sjaok
Re: Adalight not showing right colors
Postby elmerfud » Thu Mar 08, 2012 3:32 pm
That does sound odd. It could be a problem with the video capture/scanning. Have you tried running the colorswirl test code to see if it outputs correctly? If the colorswirl works, that would seem to indicate that serial communication to the Arduino, the Arduino, and the LED's are working correctly.
elmerfud
Postby pburgess » Thu Mar 08, 2012 3:46 pm
Sounds like they're not receiving power, or enough power. What are you using as a power supply? And any chance you could post a picture of your wiring?
pburgess
Postby sjaok » Fri Mar 09, 2012 7:44 pm
I will try to run the colorswirl.
The attachment 20120113_0020202.jpg is no longer available
For PSU i use the one thats in the project pack for Adalight.
I have 36 leds connected. Wiring on the picture attached.
sjaok
Postby pburgess » Fri Mar 09, 2012 8:11 pm
Ah, okay. Could you try something for me?
In the LEDstream sketch (which gets uploaded to the Arduino), could you please try changing this line (#103):
  SPI.setClockDivider(SPI_CLOCK_DIV8);  // 2 MHz
to this:
  SPI.setClockDivider(SPI_CLOCK_DIV16);
Upload to the board, then try colorswirl in Processing again. Lemme know if that clears it up, thanks.
pburgess
Postby sjaok » Sun Mar 11, 2012 6:16 pm
I tried running Colorswirl this evening, pburgess.
It shows all the right colours when running colorswirl, both with or without the change in the code.
sjaok
Postby sjaok » Sun Mar 11, 2012 6:38 pm
I tried running Lightpack after i uploaded the LEDstream-code, now everything works PERFECT.
Thanks for helping me out!
sjaok
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
New Products [103]
LEDs[109]
Cables[61]
