the allmost 20 ms offset delay of the xoxbox when its in midisync starts to gets a bit limiting or me..
are there any alternativ OS out there that have a faster response to midi sync or an adjustable delay?
greets
sven
3phase wrote:Hello,
greets
sven
3phase wrote:it has nothing to do with the sequenzer..
I checked against the other machines on the same master clock... and relativ to my G2 the xox is 806 samples later with the standard os and 860 samples later with the sokos
Sokkan wrote:There is no intentional delay in the firmware.
Guests post clearly states the delay to be 5ms.
I have personally never had a problem with any type of syncing with the x0xb0x.
Note that there is a big difference in a synth responding to midi vs midi clock. Some software sequencers have problems with sending midi clock but have no problems in sending midi note on.
Do you get the same delay if you set your x0xb0x to MIDI mode and send it midi notes as if you send it midi clock and sync it?
How did you synchronize the G1 to midi clock, or did you send it midi notes(big difference)?
Users browsing this forum: mibignistinly and 3 guests
