I'm trying to create a remote feed with temperature/humidity data from a DHT22 and BMP085 and was wondering about how to send data over the Xbee + sensors located outside to an Xbee inside attached to an LCD. I've taken a look at a lot of the tutorials and I understand how to put the Xbees together and update the units via a FTDI cable. What I'm still puzzled by is how to get the data from the remote Xbee to the indoor Xbee. It looks like I would connect the data out pin from the DHT22 to the RX pin on the remote Xbee and would connect the SDA pin from the BMP085 to the RX as well. Then, indoors, I would read data from the indoors Xbee on pin TX and would connect that to my LCD. Does it sound like I've got this correct? I'm not sure how to send data from 2 different sensors over a single Xbee and want to ensure that I'm doing this correct.
Also, I'd like to make sure that I'm ordering the right parts for this project.
Parts List:
1) Two Xbee modules - id 128
2) Two Xbee adapters - id 126
3) FTDI cable - id 70
4) power - not sure what type of battery pack to use
