I have problem with SD card read speed, when using SdFat lib.
root dir contains: index.htm with link on style.css, 3 javascript files and 2 png images
I'm using MEGA 2560 rc3 with Ethernet Sield rc3 and microSD card 4GB FAT32
sketch for web server:
- Code: Select all
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
/************ ETHERNET STUFF ************/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 177 };
char rootFileName[] = "index.htm";
EthernetServer server(80);
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
Serial.begin(9600);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_FULL_SPEED, 4)) error("card.init failed!");
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
Serial.println();
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
Serial.println();
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
Serial.println();
PgmPrintln("Done");
// Debugging complete, we start the server!
Ethernet.begin(mac, ip);
server.begin();
// How big our line buffer should be. 100 is plenty!
#define BUFSIZ 512
void loop()
char clientline[BUFSIZ];
char *filename;
int index = 0;
int image = 0;
EthernetClient client = server.available();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
// reset the input buffer
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// If it isn't a new line, add the character to the buffer
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
filename = 0;
// Print it out for debugging
Serial.println(clientline);
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0) {
filename = rootFileName;
if (strstr(clientline, "GET /") != 0) {
// this time no space after the /, so a sub-file
if (!filename) filename = clientline + 5; // look after the "GET /" (5 chars)
// a little trick, look for the " HTTP/1.1" string and
// turn the first character of the substring into a 0 to clear it out.
(strstr(clientline, " HTTP"))[0] = 0;
// print the file we want
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println("Content-Type: text/html");
client.println();
client.println("<h2>File Not Found!</h2>");
break;
Serial.println("Opened!");
client.println("HTTP/1.1 200 OK");
if (strstr(filename, ".htm") != 0)
else if (strstr(filename, ".css") != 0)
client.println("Content-Type: text/css");
else if (strstr(filename, ".png") != 0)
client.println("Content-Type: image/png");
else if (strstr(filename, ".jpg") != 0)
client.println("Content-Type: image/jpeg");
else if (strstr(filename, ".gif") != 0)
client.println("Content-Type: image/gif");
else if (strstr(filename, ".3gp") != 0)
client.println("Content-Type: video/mpeg");
else if (strstr(filename, ".pdf") != 0)
client.println("Content-Type: application/pdf");
else if (strstr(filename, ".js") != 0)
client.println("Content-Type: application/x-javascript");
else if (strstr(filename, ".xml") != 0)
client.println("Content-Type: application/xml");
else
client.println("Content-Type: text");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
// uncomment the serial to debug (slow!)
//Serial.print((char)c);
client.print((char)c);
file.close();
} else {
// everything else is a 404
client.println();
break;
// give the web browser time to receive the data
//delay(1);
client.stop();
766KB loading about 5min
I combined all the .htm .js .css files in one index.htm, without .png and try run this sketch:
- Code: Select all
#include <SPI.h>
#include <SD.h>
#define BUFFER_SIZE 512
#define ETH_SS 10
#define SD_SS 4
void setup()
pinMode(ETH_SS, OUTPUT);
digitalWrite(ETH_SS, HIGH);
SD.begin(SD_SS);
digitalWrite(SD_SS, HIGH);
digitalWrite(ETH_SS, LOW);
server.begin();
void loop()
byte buff[BUFFER_SIZE];
if (client) {
bool eol = false;
if (c == '\r')
continue;
if (c == '\n' && eol) {
File f = SD.open("index.htm");
if (f) {
client.println();
while (true) {
int n = f.read((char*)buff, BUFFER_SIZE);
if (!n)
break;
client.write(buff, n);
f.close();
} else {
client.println("Content-Type: text/plain");
client.println();
client.println("Not found");
client.println();
break;
eol = (c == '\n');
client.stop();
now 231KB loading about 4.7 sec
and is work more than 20 times faster, but i can't use separated .css and .js files...
have any idea where there may be a mistake?
