Arduino Uno R3 board, Disabled Serial Port
Postby siddharthx64 » Mon Mar 19, 2012 1:22 pm
Hey guys,
I recently purchased an Arduino Uno R3 board, and I connected it to my Laptop running Fedora 16 (64bit) with my old (no longer used) printer's USB cable.
I was able to connect it, but for a few times, the IDE (0022) showed my serial port disabled in the tools. Funnily, when I ran the ide as root, the port became magically available.
I sorted this issue by adding myself to the lockout and dial user groups, as suggested by the ide
I was able to run a led blink program on arduino without probs for 2 days
However, just today, A wierd issue started cropping up.
The serial Port stays disabled. no matter whether Im root or normal user. Moreover, Sometimes, when I connect the device to lappie, the power and led 13 keep blinking simultaneously, with interval of about 100 ms, 4 to 6 times, and go off altogether, like it isn't connected at all.
I am guessing that this is an issue with the cable, and am in the process of procuring a new cable. But just to make sure that this is not some other problem altogether, Im posting this here.
These are the messages i get in /var/log/messages when I plug the cable to the PC.
Mar 19 20:42:51 venom kernel: [  432.855743] usb 2-1.2: new full-speed USB device number 8 using ehci_hcd
Mar 19 20:42:51 venom kernel: [  432.banned] usb 2-1.2: device descriptor read/64, error -32
Mar 19 20:42:51 venom kernel: [  433.092481] usb 2-1.2: device descriptor read/64, error -32
Mar 19 20:42:52 venom kernel: [  433.266289] usb 2-1.2: new full-speed USB device number 9 using ehci_hcd
Mar 19 20:42:52 venom kernel: [  433.329220] usb 2-1.2: device descriptor read/64, error -32
Mar 19 20:42:52 venom kernel: [  433.503027] usb 2-1.2: device descriptor read/64, error -32
Mar 19 20:42:52 venom kernel: [  433.676837] usb 2-1.2: new full-speed USB device number 10 using ehci_hcd
Mar 19 20:42:52 venom kernel: [  434.078239] usb 2-1.2: device not accepting address 10, error -32
Mar 19 20:42:52 venom kernel: [  434.151311] usb 2-1.2: new full-speed USB device number 11 using ehci_hcd
Mar 19 20:42:53 venom kernel: [  434.552718] usb 2-1.2: device not accepting address 11, error -32
Mar 19 20:42:53 venom kernel: [  434.552896] hub 2-1:1.0: unable to enumerate USB device on port 2
Mar 19 20:42:59 venom dbus-daemon[1114]: ** Message: No devices in use, exit
What does this mean?
Please Help!
siddharthx64
Re: Arduino Uno R3 board, Disabled Serial Port
Postby adafruit » Mon Mar 19, 2012 1:35 pm
hiya!
is this an arduino purchased from adafruit?
thanks!
adafruit support
Postby siddharthx64 » Tue Mar 20, 2012 4:44 am
It is not bought directly from Adafruit Industries, I got it from a supplier (Tenet Technetronics, banned, India)
siddharthx64
Postby adafruit » Tue Mar 20, 2012 7:56 am
siddharthx64 wrote:It is not bought directly from Adafruit Industries, I got it from a supplier (Tenet Technetronics, banned, India)
hiya!
tenet does not purchase arduino unos from us, you might want to contact them directly for support.
thanks!
adafruit support
Return to Arduino
Users browsing this forum: No registered users and 8 guests
New Products [103]
LEDs[109]
Cables[61]
