The assembled minipov3 worked fine with sequencing the led's.
On to avrdude, I followed instructions to load initial minipov.h through serial port and this is where the problem starts. When I connect the blinking unit to the serial port, with and without an extension serial cable, the lights stop sequential blinking. No dimmimg as reported somewhere in the forum.
typing: make program-minov in my c:\minipov3 directory the following error message appears:
avrdude -p atttiny2313 -p com1 -c dasa -uflash:w:minipov.hex
avrdude: ser_open(): cant set buffers for "com1"
avrdude: serbb_setpin():setcommstate()failed:the handle is invalid
make:***[program make-minipov] error 1
c:\minipov3>
I get the same error wether the unit is turned on or off.
I tried to trouble shoot the serial port with windows troubleshooter but no error found.
I connected an old serial mouse to the serial port and it worked ok and was recognized in device manager.
The minipov3 does not appear at all in device manager whether on or off. Is that normal?
I''m using an old XP I keep for emergencies, that happens to have a serial port.
All soldering appears good.
Would appreciate any further suggestions
PBC
