Monochrome 128x32 OLED bad pixels
Postby fat16lib » Tue Mar 06, 2012 8:41 am
I bought three Monochrome 128x32 OLED displays but was surprised that each had a bad pixel. The bad pixel is in a different spot on each display. Is this normal?
I love the display and wrote a character only library to eliminate the 512 byte RAM buffer. This library also allows both bit-bang and hardware SPI so it works well with the Data Logging shield.
Here is an example data logger with an 18-bit MCP3422 differential delta-sigma ADC and the 128x32 display.
At max gain the LSB of the MCP3422 is about two micro-volts so it can log voltages a thousand times smaller than the Arduino ADC.
fat16lib
Re: Monochrome 128x32 OLED bad pixels
Postby adafruit » Tue Mar 06, 2012 10:41 am
thats very unusual, we have never seen a bad pixel, can you demonstrate it by filling the screen?
Postby fat16lib » Tue Mar 06, 2012 1:57 pm
Below are the pictures. Yes I did remove the protective film. Sorry Display3 is a bit fuzzy.
I looked at the displays with a 10X loupe and it appears to be dirt or a defect between the two layers of glass. It is not on the outer surface.
Look at display2, my best picture. It has a large piece of dirt or defect that doesn't line up with pixels.
Display1:
Display2:
Display3:
fat16lib
Postby adafruit » Tue Mar 06, 2012 2:34 pm
thanks, we will update our test to help us identify this issue (our current one just draws an image)
you can email support@adafruit to get replacements
Postby fat16lib » Wed Mar 21, 2012 1:29 pm
I Received the three new Monochrome 128x32 OLED displays last week and finally tested them. All three are perfect!
Thanks for the great service Adafruit.
fat16lib
Return to Glowy things (LCD, LED, TFT, EL) purchased at Adafruit
Users browsing this forum: toreseng and 3 guests
New Products [113]
Raspberry Pi[81]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
