PC previously installed FreeDuino and now can't install Uno
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
Postby lllxjy » Sat Mar 24, 2012 7:21 pm
So I have this PC previously installed with FreeDuino and FTDI drivers. Now when I connect my Uno with my PC, it can't recognize the board. I tried to update the driver manually (tried both from the FTDI folder and the driver folder which has AruinoUno.inf) but it still doesn't work. It says it's already the latest version and doesn't update anything. I tried to uninstall the FreeDuino device from the device manager but it seems not the solution. Everytime I connect the FreeDuino again, the driver just automatically install itself.
I guess I need to remove the older version of FTDI drivers on PC and re-install the correct version? Any idea how I can do that?
Thanks a bunch!
lllxjy
Re: PC previously installed FreeDuino and now can't install Uno
Postby westfw » Sat Mar 24, 2012 10:04 pm
The Uno doesn't have an FTDI chip. You have to install the drivers that go with the Uno (either "Arduino UNO.inf" or "Arduino UNO R3.inf" (these aren't actually drivers, they're just descriptors that say "This is a serial-port-like devices and you should use the usb serial port drivers that are already part of windows", but they still need to be installed.)
westfw
Postby lllxjy » Sun Mar 25, 2012 9:52 am
Thanks for your reply!
I read other posts saying that your Uno board should show "Uno" under the Port (COM&LPT) in device manager.
http://arduino.cc/en/Guide/UnoDriversWindowsXP
Mine only shows "unknown device" under "Other devices". I'm not sure if it makes a difference, but I can't install the "Arduino Uno.inf" driver from device manager. It says it's the latest driver and doesn't do anything. Is there other ways I can install the Arduino Uno files?
lllxjy
Postby adafruit_support_bill » Sun Mar 25, 2012 2:21 pm
Try to un-install any existing driver first.
Postby lllxjy » Fri Jun 01, 2012 2:54 pm
Hi, I know it's been a while but this is still not solved. I have been using my friend's board during this time and it works totally fine on my laptop.
And I found this post:
viewtopic.php?f=21&t=20257
I just tried my board again and checked the log, it's exactly like the one you mentioned:
dvi: {DIF_UPDATEDRIVER_UI} 15:50:04.474
     dvi:      No class installer for 'Unknown Device'
     dvi:      No CoInstallers found
     dvi:      Default installer: Enter 15:50:04.489
     dvi:      Default installer: Exit
Is it possible for me to get a replacement?
lllxjy
Postby adafruit_support_bill » Fri Jun 01, 2012 3:58 pm
Yes, it has been a couple of months.
The symptom you describe is consistent with the 8u2 chip losing its programming. And it is typically correctable - as noted further down in the link you posted. http://forums.adafruit.com/viewtopic.php?f=21&t=20257#p122255
Postby lllxjy » Fri Jun 01, 2012 4:07 pm
Hi- Thanks for the reply. Good to see it can be fixed but unfortunately I don't have a USBtinyISP...
Any other suggestions? Is there anyway I can get a replacement?
lllxjy
Return to Arduino Starter Pack
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
