adafruit_support wrote:The tutorial is applicable to any module that has Tx, Rx, VCC and Gnd connections. http://www.ladyada.net/make/gpsshield/wiring.html
Check the 408 specs to find the pinouts: http://www.usglobalsat.com/store/download/47/em408_ug.pdf
adafruit_support wrote:That you will have to determine by experimentation. I don't have a 408 module here to check.
adafruit_support wrote:What code are you trying to use?
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:11: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:11: undefined reference to `loop'
adafruit_support wrote:Post the full text of the sketch you are using. The compiler is telling you that it can't find your setup and loop functions./Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:11: undefined reference to `setup'
// A simple sketch to read GPS data and parse the $GPRMC string
// see http://www.ladyada.net/make/gpsshield for more info
// If using Arduino IDE prior to version 1.0,
// make sure to install SoftwareSerial from Mikal Hart
// http://arduiniana.org/libraries/SoftwareSerial/
#if ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
#else
#include "WProgram.h"
#endif
// Use pins 2 and 3 to talk to the GPS. 2 is the TX pin, 3 is the RX pin
#if ARDUINO >= 100
SoftwareSerial mySerial = SoftwareSerial(2, 3);
#else
#endif
// Use pin 4 to control power to the GPS
#define powerpin 4
// Set the GPSRATE to the baud rate of the GPS module. Most are 4800
// but some are 38400 or other. Check the datasheet!
#define GPSRATE 4800
//#define GPSRATE 38400
// The buffer size that will hold a GPS sentence. They tend to be 80 characters long
// so 90 is plenty.
#define BUFFSIZ 90 // plenty big
// global variables
char buffer[BUFFSIZ]; // string buffer for the sentence
char *parseptr; // a character pointer for parsing
char buffidx; // an indexer into the buffer
// The time, date, location data, etc.
uint8_t hour, minute, second, year, month, date;
uint32_t latitude, longitude;
uint8_t groundspeed, trackangle;
char latdir, longdir;
char status;
void setup()
if (powerpin) {
pinMode(powerpin, OUTPUT);
// Use the pin 13 LED as an indicator
pinMode(13, OUTPUT);
// connect to the serial terminal at 9600 baud
Serial.begin(9600);
// connect to the GPS at the desired rate
mySerial.begin(GPSRATE);
// prints title with ending line break
Serial.println("GPS parser");
digitalWrite(powerpin, LOW); // pull low to turn on!
uint32_t parsedecimal(char *str) {
uint32_t d = 0;
while (str[0] != 0) {
if ((str[0] > '9') || (str[0] < '0'))
return d;
d *= 10;
d += str[0] - '0';
str++;
return d;
void readline(void) {
char c;
buffidx = 0; // start at begninning
while (1) {
c=mySerial.read();
if (c == -1)
continue;
Serial.print(c);
if (c == '\n')
continue;
if ((buffidx == BUFFSIZ-1) || (c == '\r')) {
buffer[buffidx] = 0;
return;
buffer[buffidx++]= c;
void loop()
uint32_t tmp;
Serial.print("\n\rRead: ");
readline();
// check if $GPRMC (global positioning fixed data)
if (strncmp(buffer, "$GPRMC",6) == 0) {
// hhmmss time data
parseptr = buffer+7;
tmp = parsedecimal(parseptr);
hour = tmp / 10000;
minute = (tmp / 100) % 100;
second = tmp % 100;
parseptr = strchr(parseptr, ',') + 1;
status = parseptr[0];
parseptr += 2;
// grab latitude & long data
// latitude
latitude = parsedecimal(parseptr);
if (latitude != 0) {
latitude *= 10000;
parseptr = strchr(parseptr, '.')+1;
latitude += parsedecimal(parseptr);
// read latitude N/S data
if (parseptr[0] != ',') {
latdir = parseptr[0];
//Serial.println(latdir);
// longitude
parseptr = strchr(parseptr, ',')+1;
longitude = parsedecimal(parseptr);
if (longitude != 0) {
longitude *= 10000;
longitude += parsedecimal(parseptr);
// read longitude E/W data
longdir = parseptr[0];
// groundspeed
groundspeed = parsedecimal(parseptr);
// track angle
trackangle = parsedecimal(parseptr);
// date
date = tmp / 10000;
month = (tmp / 100) % 100;
year = tmp % 100;
Serial.print("\n\tTime: ");
Serial.print(hour, DEC); Serial.print(':');
Serial.print(minute, DEC); Serial.print(':');
Serial.println(second, DEC);
Serial.print("\tDate: ");
Serial.print(month, DEC); Serial.print('/');
Serial.print(date, DEC); Serial.print('/');
Serial.println(year, DEC);
Serial.print("\tLat: ");
if (latdir == 'N')
Serial.print('+');
else if (latdir == 'S')
Serial.print('-');
Serial.print(latitude/1000000, DEC); Serial.print("* ");
Serial.print((latitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
Serial.print((latitude%10000)*6/1000, DEC); Serial.print('.');
Serial.print(((latitude%10000)*6/10)%100, DEC); Serial.println('"');
Serial.print("\tLong: ");
if (longdir == 'E')
Serial.print('+');
else if (longdir == 'W')
Serial.print('-');
Serial.print(longitude/1000000, DEC); Serial.print("* ");
Serial.print((longitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
Serial.print((longitude%10000)*6/1000, DEC); Serial.print('.');
Serial.print(((longitude%10000)*6/10)%100, DEC); Serial.println('"');
//Serial.println(buffer);
}adafruit_support wrote:That code compiles with no errors on 1.0 here.
how can I get a clean installation of the arduino software ?
adafruit_support wrote:how can I get a clean installation of the arduino software ?
Right from the Arduino site is the best place: http://arduino.cc/en/Main/Software
Where did you get the IDE you are using?
Return to Arduino Shields from Adafruit
Users browsing this forum: mibignistinly and 4 guests
