Arduino UNO failed to connect
Postby Ray_RC » Mon Mar 26, 2012 8:32 pm
When I first plugged the UNO I bought from you into my computer it did not register with the computer as an Arduino; the computer only detected it as a USB device. I borrowed another UNO from a friend and it was properly detected. What should I do?
Thanks,
Ray
Ray_RC
Re: Arduino UNO failed to connect
Postby adafruit_support_bill » Tue Mar 27, 2012 4:43 am
Try selecting the USB device in the device manager and updating the driver as described in step 4 here. http://arduino.cc/en/Guide/Windows
Postby Ray_RC » Wed Mar 28, 2012 12:05 am
I did.
Please read my first post carefully. It does show up. But NOT as an Arduino, just as a USB device.
Thanks...
Ray
Ray_RC
Postby Ray_RC » Wed Mar 28, 2012 4:17 am
P.S. The reason I think the Arduino UNO you sent me has failed is the fact the UNO I borrowed worked fine. Would it help to try hooking the one from you up, now that the driver is installed?
Ray_RC
Postby adafruit_support_bill » Wed Mar 28, 2012 5:36 am
Try it. Sometimes an UNO will show up under "Other Devices" or "USB Devices". In either case, updating the drivers usually works.
In rare cases where the 16U2 is not functioning properly the driver update will fail. If this is the case we will replace the board.
Postby Ray_RC » Wed Mar 28, 2012 8:08 pm
Ok, I did try it and it still didn't work :(. So I suppose it is bad. Do I send it back, and if so what kind of documentation do you need with it?
Ray_RC
Postby Ray_RC » Fri Mar 30, 2012 12:52 pm
How do I send this back?
Ray_RC
Return to Arduino
Users browsing this forum: buton, mibignistinly and 7 guests
New Products [102]
LEDs[109]
Cables[60]
