It's great that I2C allows you to connect multiple devices to your Arduino but I haven't found any good way to handle the connections. I'm looking for a really simple board that has five or six I2C connections on it (ideally just 4 pin JST RE but could be any standard connector). I think the pins can just be passively connected. I could try to make one, but the odds of me correctly soldering 24 pins that are that close together are about 1 in never. I've seen one I2C hub on the market but it only has 4 connectors which means if you daisy chain two of them you only end up with 5 usable connections.
Also, THANKS for producing the 3v/5v I2C level convertor - just got one of those which will solve my problem of mixing 3v and 5v i2c devices.
