GPS shield working with chip removed not with sample sketch
Postby virtualbrooklyn » Sun Apr 01, 2012 8:13 pm
I connected the GPS shield by removing the ATmega328 chip from the arduino as per tutorial, and I get data from the serial monitor.
However, when I put the chip back and run the sample sketch, I get the following read only:
ÿ
virtualbrooklyn
Re: GPS shield working with chip removed not with sample sketch
Postby adafruit_support_bill » Mon Apr 02, 2012 4:53 am
Make sure the baud-rate setting of your serial monitor matches the baud-rate in the sketch (9600).
Postby virtualbrooklyn » Mon Apr 02, 2012 6:41 am
Yes. I did change that. It is set at 9600.
virtualbrooklyn
Postby adafruit_support_bill » Mon Apr 02, 2012 6:56 am
If you post photos of the front & back of the board, well take a look for any assembly problems.
Postby virtualbrooklyn » Mon Apr 02, 2012 7:23 am
Thank you. Here are the photos.
gps 2.jpg (697.72 KiB) Viewed 786 times
Thank you.
virtualbrooklyn
Postby adafruit_support_bill » Mon Apr 02, 2012 10:43 am
You have some incompletely soldered header pins on the top side. And on the bottom there are leads that should be clipped closer to the board.
Not sure if it is just the lighting, but some of the pins of the IC look a bit solder-starved and the solder joint 4th pin from the top on the SD card holder looks suspicious too.
Postby virtualbrooklyn » Mon Apr 02, 2012 11:41 am
I fix that, but I think that the problem might be that the resistors (R1 and R2) are connected incorrectly. Can you see it?
Thanks again.
virtualbrooklyn
Postby adafruit_support_bill » Mon Apr 02, 2012 11:51 am
Yes. R1 and R2 are in the wrong location. These resistors are current limiters for the LEDs, so they would not be the cause of the communication problem.
Postby virtualbrooklyn » Mon Apr 02, 2012 12:11 pm
Makes sense. It's there a way of testing continuity with a digital meter to pinpoint the cause of the problem? How else can troubleshoot?
virtualbrooklyn
Postby adafruit_support_bill » Mon Apr 02, 2012 12:28 pm
How do you have the Rx/Tx jumpers connected? In the photo, they are still connected to pins 0 & 1 as for the test with the Arduino chip removed.
Postby virtualbrooklyn » Mon Apr 02, 2012 1:53 pm
Awesome. That was it. I had left the TX/RX jumpers connected to pin 0 and 1 for test with the chip removed. I changed them to pins 2 and 3, PWR to 4, kept the original sketch and it all worked. YAY!!!
One last thing, I have an Otterbox and when I put the board the TX jumper is a bit high. It bends a little making the closing just a bit hard. No big deal, but just checking to see if I can cut it or something. What's that jumper used for?
Thanks a lot for the help. I am happy. :D
virtualbrooklyn
Postby adafruit_support_bill » Mon Apr 02, 2012 2:59 pm
The jumper allows you to disconnect data transmission from the GPS module. You can clip the plastic tab off the top of the jumper if it fits better.
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 6 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
