SOLVED USBtinyISP green light turns of when target connected
Postby alexshel44 » Sun Apr 01, 2012 10:38 pm
1. I'm building the project from a kit.
2. I'm running Ubuntu 11.10 on a Toshiba Satellite C650D laptop
3. I'm using avrdude for programming and attempting to program an atmega 16
4. This is the first time i've tried to talk to the chip
5. I will post pictures in the next couple days if required
I just finished building the USBtinyISP kit, and when i connect the programmer to the computer without a target connected
the greenlight turns on and avrdude detects the programmer with the following message:
awsheldo@awsheldo-Satellite-C650D:~$ avrdude -c usbtiny -p m16
avrdude: error: usbtiny_transmit: error sending control message: Operation not permitted
         this check.
avrdude done.  Thank you.
which makes sense since nothing is connected but,
Once, I plug the target into the programmer using the 6 pin header the greenlight turns off and when trying to talk to the chip
avrdude shows the following error message:
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
If anyone could help try and help debug this problem that would be great.
Thanks in advance for any help
Alex
alexshel44
Re: USBtinyISP green light turns of when target connected
Postby DX160 » Mon Apr 02, 2012 12:23 pm
The Green LED is USB power, if that goes out when you connect to your target device something isn't right.
Is the 6pin right on the USBtiny side?
Got the right alignment on the device side?
There's an arrow on those 6pin connector bodies indicating pin 1.
Unfortunately, pin#1 is not Ground, it's MISO.
Pin#2 is +5 (+V) and pin#6 is Ground.
Check, Double Check, and then Check again.
DX160
Postby alexshel44 » Mon Apr 02, 2012 6:24 pm
Thanks a lot for the reply
I rechecked the attiny on the programmer is getting power but, only 4.3V.
I also remade my target board currently, the minamalist target board from evil mad scientist
http://www.evilmadscientist.com/article.php/avrtargetboards
The greenlight now remains on if the target is connected.
But, i get the following message
         this check.
both the vcc pin and the reset pins on the target chip are getting ~4V could this be causing
the chip to brown out or reset, if so what could be a possible cause for that low of a voltage
Thanks,
Alex
alexshel44
Postby alexshel44 » Mon Apr 02, 2012 9:59 pm
Thank you
The problem is solved and the programmer is officially working
Alex
alexshel44
Return to USBtinyISP
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
