RGB LCD Shield, text won't display.
Postby mxtxee » Mon Apr 02, 2012 7:07 am
Be gentle, I'm a little new to all of this :o When I run the HelloWorld example program from the library, the backlight comes on and I can change the color of the backlight with the buttons, but I'm not getting any text. I went through each solder joint and they all seem solid.
What else can I do to troubleshoot?
mxtxee
Re: RGB LCD Shield, text won't display.
Postby adafruit_support_bill » Mon Apr 02, 2012 7:19 am
If you post photos of the front & back of the shield well take a look.
Postby adafruit » Mon Apr 02, 2012 9:41 pm
did you adjust the contrast pot?
Postby mxtxee » Tue Apr 03, 2012 7:48 pm
I tried adjusting the potentiometer and that didn't work. Now that I look at pictures of my soldering, it looks awful. Sigh.
Here you go:
mxtxee
Postby mxtxee » Tue Apr 03, 2012 7:54 pm
Hooray! After taking pictures of the joints, I patched up a few, played with the potentiometer a little more and voila!!
It works! Thanks for the help.
mxtxee
Postby adafruit_support_bill » Tue Apr 03, 2012 8:06 pm
The solder joints on the header pins of the display board look very good. The one on the header pins of the shield look a bit suspicious. They are smooth and shiny, which is good. But they appear to be balled up around the pin and may not have flowed well onto the surrounding solder pad. The ideal joint cross-section is concave as in the diagram below.
Solder Joint.gif (7.78 KiB) Viewed 728 times
Postby mxtxee » Wed Apr 04, 2012 8:14 am
Yep! I re-heated two of the joints that looked too convex around the pin and then it worked perfectly. Thanks again!
mxtxee
Return to Arduino Shields from Adafruit
New Products [103]
LEDs[109]
Cables[61]
