Larger EEPROM supported?
SpokePOV kit for bikes
Postby mfagan » Wed May 30, 2007 1:07 am
I am looking at larger eeproms from mouser and wanted to know if they are supported by the kit and software (for PC)
http://www.mouser.com/search/ProductDet ... C256-I%2fP (256kb)
http://www.mouser.com/search/ProductDet ... C640-I%2fP (64kb)
Mike
mfagan
Postby wcravens » Wed May 30, 2007 9:00 am
They will not work unless you modify both software and firmware. I am assuming (without looking) pin and function compatability with the eeproms that already exist.
wcravens
Postby adafruit » Wed May 30, 2007 11:26 am
its true, they dont work right now, although one day ill finally make it so it does... :)
Postby mfagan » Thu May 31, 2007 9:24 pm
I looked at the firmware and it looks like it will support the 64KB chip unmodified since it already uses 16bit addresses.
It looks like the only modification is to the software to probe for memory larger than 4x.
Unless I entirely missed something.
mfagan
Postby adafruit » Thu May 31, 2007 9:34 pm
yup thats pretty much it :)
Postby Bronto » Thu May 31, 2007 11:11 pm
Does this translate into more frames of animation? Because that would be great.
Bronto
Postby mfagan » Mon Jun 11, 2007 9:06 am
I have updated the source file to support larger eeproms but I need to test it.
Is there any docs/links about setting up the development env for windows?
mfagan
Postby adafruit » Mon Jun 11, 2007 10:42 am
its called "mingw" there is some terrible documentation about it online ;)
if you send me just the changes ill add it to the next revision which is going to be very soon (like 2 weeks)
Postby Delphium » Tue Mar 04, 2008 7:04 pm
Having more than 4 frames would be awesome. Is it possible to have the 64KB chip for sale (or an option) with the kit?
Delphium
Postby adafruit » Thu Mar 06, 2008 5:26 pm
current software is tested with up to 16 frames (16KB/128Kbit), but not lots of testing
Return to SpokePOV
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
