Fluctuating amps with Mintyboost
Postby luca662 » Sat Apr 14, 2012 12:35 pm
So I just built my mintyboost and I'm testing it with my Samsung Vibrant. It charges very slowly. I installed this app on my phone that shows me the charging rate of my charger. For my wall outlet it shows a constant 1100 mA. When I use my mintyboost, the mA bounces around. It goes from 0 mA to ~600 mA to ~200 mA then back down to zero. There doesn't seem to be pattern to it either. The numbers are always random, but its 0 at least half of the time. When I use my volt meter to check the voltage of the USB pins, it is at a solid 4.97V and does not fluctuate. I tried using rechargeable 2500maH NiMH batteries as well as brand new duracell AA's.
Pictures:
http://i.imgur.com/dXibD.jpg
http://i.imgur.com/Rh4g6.jpg
The app I used is called "CurrentWidget" for android phones.
Any help would be appreciated!
luca662
Re: Fluctuating amps with Mintyboost
Postby adafruit_support_bill » Sat Apr 14, 2012 12:43 pm
The Mintyboost can handle up to a 500mA charge rate. It looks like the phone is trying to pull more than that and the boost converter is going into thermal shutdown.
Postby luca662 » Sat Apr 14, 2012 12:45 pm
the IC isn't even warm to the touch and neither are the batteries. This was after I had it plugged in for a while. Is there also a way to fix this problem?
Edit: I saw that most phone is listed as being a supported device for the minty boost.
luca662
Postby adafruit_support_bill » Sat Apr 14, 2012 1:38 pm
If the IC isn't warm and the widget is reporting 600mA current draw, I would tend to doubt the widget. Better to test with a multimeter in the circuit.
Have you tried bridging D1 and D2?
Postby luca662 » Sat Apr 14, 2012 2:01 pm
The widget was reporting that the draw was bouncing widly between the range 0-600, but it was at 0 for almost half the time. D1 and D2 are bridged. No worries now because I fixed my problem. It was the usb cable I was using. I switched the a different cable and it works flawlessly. The widget reports a draw between ~600-850 with an average around ~750 with the different cable. It still fluctuates wildly, but stays in that range. The IC is slightly warm now and my phone has charged 5% already. Unfortunately I don't have a multimeter to accurately measure the mA.
This is the cable I was using that didn't work:
http://www.amazon.com/gp/product/B003YKX6WM/ref=oh_o00_s01_i00_details
It works fine when connected to my computer, but not on the mintyboost. Any ideas?
luca662
Postby adafruit_support_bill » Sat Apr 14, 2012 2:12 pm
Cables often do make a difference. Although extra long ones are usually more prone to voltage drops. Sometimes also it is a problem with the connectors not making good contact.
Postby luca662 » Sat Apr 14, 2012 2:50 pm
Thank you so much for your help!
luca662
Return to MintyBoost
New Products [103]
LEDs[109]
Cables[61]
