Green LED never turns on
Postby vectorspace » Mon Feb 06, 2012 10:34 pm
I received my USBtinyISP kit today (127619) and built it this evening.
The green LED does not and has never lit up. I would appreciate any suggestions you may have.
I have verified that the LEDs, zener diodes, ICs and the electrolytic capacitor are oriented correctly, verified that the correct resistors are in place, tried three USB cables, tried all five USB ports on the computer, reseated the ATtiny2313 MCU, and re-heated all solder joints.
I measured 5 volts from the USB port on the power pins of the ICs and headers, and the oscillator waveform is showing up on pins 4 and 5 of the MCU. Pins 1 and 20 are HI and all other MCU pins are LO. The 74AHC125 has pin 14 HI and all other pins LO.
My computer is a 2.0 GHz Intel Core2 Quad Lenovo Thinkpad W700 running Windows Vista Business 64 bit with 6 GB of RAM.
I haven't gotten past plugging the USB cable in and looking for the green LED to light so the programming software, chip, screenshots don't seem useful at this time.
The front and back pictures of my USBtinyISP are below:
Back
vectorspace
Re: Green LED never turns on
Postby adafruit » Tue Feb 07, 2012 11:02 am
Does it ask you to install the driver?
Postby vectorspace » Tue Feb 07, 2012 12:56 pm
No, I see no reaction from the computer of any kind when the USB cable is connected. I also tried it on another computer (at work) and the result (actually, the lack thereof) was exactly the same.
vectorspace
Postby adafruit » Tue Feb 07, 2012 2:00 pm
hmm, can you check the crystal value?
Postby vectorspace » Tue Feb 07, 2012 2:57 pm
It is marked ZTT 12.00MT and, as I remember it, it was running at 11.996 MHz or so when I checked it last night.
vectorspace
Postby adafruit » Tue Feb 07, 2012 9:03 pm
hmm ok, lets try a new chip. email support@adafruit and ask for a new USBtiny micro!
Postby vectorspace » Sat Feb 11, 2012 3:27 pm
Got it. Tried it. It works perfectly now.
THANKS.
This great support from adafruit is to be commended!!!!!
vectorspace
Postby Mikesku » Thu Apr 12, 2012 4:22 pm
Hello!
I have exactly the same problem, I soldered the usbtinyisp board and checked all the routes and everything looks ok, the attiny2313 has 5V supply but it doesn't work.
If it is necessary I'll post some photos tomorrow, but please give me a solution as soon as posible because I have to finish a project.
Thank you very much in advance. Regards,
Mikel
Mikesku
Postby Mikesku » Fri Apr 13, 2012 7:51 am
Here are the photos. I checked the crystal clock with the oscilloscope and it works fine, 12kHz.
I look forward to hearing from you,
Mikel
Mikesku
Postby adafruit_support_bill » Tue Apr 17, 2012 2:56 pm
Your build looks fine. Let's see if yours is a chip problem too.
Contact support@adafruit.com with a link to this thread and ask for a new USBtiny micro.
Return to USBtinyISP
Users browsing this forum: Google [Bot] and 1 guest
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
