2.8" TFT Breakout Board (#335) - Physical drawing
Postby plut0nium » Wed Apr 18, 2012 6:28 am
Hi
I just bought the 2.8" 18-bit color TFT LCD with touchscreen breakout board (product ID # 335) and plan to use it on a custom home-made PCB, basicaly like an Arduino shield, but not on an Arduino :lol:
I'd like to create an Eagle Library of this product to design my circuit. And to get the best results, I need a physical drawing of it with the precise dimensions and placement of the headers... Does this exist ? or are the eagle files (*.sch and *.brd) available :?: just like for the 2.8" TFT Touch Shield for Arduino - 2.8" (Product ID # 376)
The only information I found so far are :
Thank you,
Charles
plut0nium
Re: 2.8" TFT Breakout Board (#335) - Physical drawing
Postby plut0nium » Thu Apr 19, 2012 4:01 am
No answer ? :|
This is where I am stuck so far :
  • Board outer dimensions should be correct, based on the information given on the product page
  • Mounting hole placement too
  • Space between pads is the standard 100mil/2.54mm
  • I assumed that the space between the board edges and the pads is also 100mil, this gives a round multiple of 100mil between the two connectors
  • The connectors are center-aligned vertically
  • All other dimensions (round corners radius, width of the pcb in the center, ...) are guesses
Once I'll receive the board, I'll be able to do more precise measurements... but an actual drawing or eagle *.brd file would be nice 8)
plut0nium
Postby plut0nium » Thu Apr 19, 2012 3:58 pm
:D
Thank you so much...
plut0nium
Postby plut0nium » Thu Apr 19, 2012 4:46 pm
And all the dimensions I had guessed were correct 8)
The library is now complete, I should be able to use the breakout board as a "shield" on a custom PCB.
I'll try to upload the file somewhere, if it can be useful to anyone...
plut0nium
Postby civicbynature » Sun Mar 17, 2013 4:36 pm
I am trying to find the eagle files for adafruits 2.8 tft LCD breakout. the link provided here does not work. I just downloaded adafruit's eagle lib. but the break out is not included. So where is it now if there is one?
Please
civicbynature
Users browsing this forum: No registered users and 6 guests
New Products [103]
LEDs[109]
Cables[61]
