Working GPS shield, but 3 years later, EM-406 can't get satellite fix
Postby djakopac » Wed Apr 18, 2012 5:00 pm
I have a version 1.0 GPS Shield and EM-406 GPS module. I bought these about three years ago, assembled them and it worked great. Unfortunately, the project I was working on was put on the shelf for a while. Last weekend I fired up an Arduino Duemilanove with a 328 chip, ran the Arduino 1.0 IDE, downloaded the latest sketch (https://github.com/adafruit/SD-Basic-GPS-logger) and ran it.
Logging to SD worked perfectly and the chip spit out NMEA strings. Unfortunately, they were all of the form:
$GPRMC,235949.030,V,,,,,,,281006,,*21
(I.e., no location information and incorrect, or default, time and date info.)
I connected it up with a FTDI cable with the GPSPWR line connected to GND and am getting the same strings.
I ran it inside for several hours and outside for about 45 minutes--same results.
When I turn on the satellite output, I get:
$GPGSV,3,1,12,20,00,000,,10,00,000,,31,00,000,,27,00,000,*7C
$GPGSV,3,2,12,19,00,000,,07,00,000,,04,00,000,,24,00,000,*76
$GPGSV,3,3,12,16,00,000,,28,00,000,,26,00,000,,29,00,000,*78
which indicates 12 satellites in view, but alt and azimuth from all are 0.
The red LED on the EM-406 module is solid red when powered and the NMEA strings appear to be output at 1Hz.
Seems like the satellite processing portion of the EM-406 is not working, but the other GPS module components are working (in that they produce correct NMEA strings, albeit without location information).
Just wondering if anyone else has seen similar behavior after a long period without use or has an suggestion--other than the obvious replacement of the EM-406.
djakopac
Re: Working GPS shield, but 3 years later, EM-406 can't get satellite fix
Postby franklin97355 » Wed Apr 18, 2012 11:02 pm
The V means VOID which means you do not have a lock on enough satellites. How long did you wait for a lock and are you outside?
franklin97355
Postby djakopac » Wed Apr 18, 2012 11:23 pm
franklin97355 wrote:How long did you wait for a lock and are you outside?
I ran it outside for 45 minutes (I've made several attempts outside, the longest was 45 minutes, but several were about 10 minutes). I also tried inside near a window for several hours (at least two hours). Last time it worked, about three years ago, I got a lock within seconds outside, in the same spots. There are no tall buildings and none of these times outside was under a tree.
djakopac
Postby adafruit » Thu Apr 19, 2012 6:19 pm
we've never heard of this happening, and we have a GPS unit much older than that (the first EM406A we got) that still works. we'll try to think of what could have happened
Postby Fossum » Tue May 28, 2013 11:45 am
Funny, I have about the same issue with a somewhat new EM406. It just repeats the below text:
$GPRMC,151053.167,V,,,,,,,280513,,,N*43
$GPGGA,151054.167,,,,,0,00,,,M,0.0,M,,0000*52
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,151054.167,V,,,,,,,280513,,,N*44
$GPGGA,151055.167,,,,,0,00,,,M,0.0,M,,0000*53
$GPRMC,151055.167,V,,,,,,,280513,,,N*45
$GPGGA,151056.167,,,,,0,00,,,M,0.0,M,,0000*50
$GPRMC,151056.167,V,,,,,,,280513,,,N*46
$GPGGA,151057.167,,,,,0,00,,,M,0.0,M,,0000*51
$GPRMC,151057.167,V,,,,,,,280513,,,N*47
$GPGGA,151058.167,,,,,0,00,,,M,0.0,M,,0000*5E
$GPGSV,3,1,12,22,72,168,,14,37,026,,31,37,330,39,18,36,150,*73
$GPGSV,3,2,12,16,29,209,,25,20,035,,29,17,096,,06,09,201,*71
$GPGSV,3,3,12,21,06,153,,32,06,323,,03,-1,213,,01,-4,295,*74
It seems to have 12 satellites in view, but only one tracking... forever
Fossum
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 7 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
