Need Help with setting up USB Tiny ISP
Postby Masuod123 » Thu Apr 19, 2012 3:26 pm
I ordered the USB Tiny ISP kit from you guys, i soldered
> everything by following the tutorial in your website. When i connect it to
> the computer i get the unknown device in windows (i knew the driver is not
> installed). I went ahead and downloaded the latest driver from your website
> and when i try to install it i get this error "The specified location does
> not contain information about your hardware.( when browsing and selecting
> the .INF file)" Neither the green light nor the red light comes on when the
> USB is connected. What is the problem?
I checked some post but none seemed to help.
Thanks in advance
Masuod123
Re: Need Help with setting up USB Tiny ISP
Postby adafruit » Thu Apr 19, 2012 3:47 pm
Can you post a photo of the front and back? perhaps its a simply soldering issues we can determine
Postby Masuod123 » Thu Apr 19, 2012 4:42 pm
Here are the pictures
Front
Back
Masuod123
Postby adafruit » Thu Apr 19, 2012 6:34 pm
hmmm, can you go back and touch up the solder joints for the resistors and diodes around the USB connector?
Postby Masuod123 » Fri Apr 20, 2012 12:27 pm
I did that, it didn't seem that it helped.
Masuod123
Postby Algolosaur » Sat Apr 21, 2012 8:16 am
I don't see either a resistor or jumper in place for R4 and R7 (resistors for SpokePOV, jumpers otherwise).
Algolosaur
Veritas Vos Fugere Facet
Algolosaur
Postby adafruit » Sat Apr 21, 2012 11:34 am
Algolosaur wrote:I don't see either a resistor or jumper in place for R4 and R7 (resistors for SpokePOV, jumpers otherwise).
Algolosaur
that is not relevant, please let us help this customer :)
Masuod123 wrote:I did that, it didn't seem that it helped.
OK when you plug in, what computer OS are you using exactly
Postby Masuod123 » Mon Apr 23, 2012 10:33 am
I am using windows XP sp3 and when i plug in the the usb it says this message: One of the usb devices attached to this computer has malfunctioned and windows does not recognize it.
Masuod123
Postby adafruit » Mon Apr 23, 2012 10:36 am
OK that is a different message than you said before!
> the .INF file)"
we could try replacing the chip - email support@adafruit and request a new USBtinyISP chip
Postby Masuod123 » Mon Apr 23, 2012 12:19 pm
that is when i try to install the driver. In windows when the hardware is marked as unknown device it is because the driver is missing. I go to the device manager and right click on "unknown Device" and click properties, then i click update drivers and direct to the folder that i downloaded from ladyada. That is when i get this error not contain information about your hardware.( when browsing and selecting the .INF file)"
Masuod123
Postby Masuod123 » Mon Apr 23, 2012 12:21 pm
adafruit wrote:OK that is a different message than you said before!
> the .INF file)"
I have a question: does USBTinyISP turn on if it is not connected to the target program chip. I am trying to program an Atmega 32 with this.
Masuod123
Postby adafruit » Mon Apr 23, 2012 1:32 pm
disconnect from the target when plugging it into the computer
Return to USBtinyISP
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
